-   ECU Flash (https://www.evolutionm.net/forums/ecu-flash-179/)
-   -   Let's see your fully tuned timing maps (https://www.evolutionm.net/forums/ecu-flash/308720-lets-see-your-fully-tuned-timing-maps.html)
recompile Nov 19, 2007 08:35 PM
OK,
I'm re-tuning soon, and I want to see how far off I am from a "very good" tune. I'm particularly interested in tunes that have shown strong dyno powerbands and/or good quarter mile trap speeds.
So please, post your timing map!
I'll start with mine that I'm running as of today (this is straight 93, I run 25psi, with a taper to 20 at redline... still on stock turbo, stock WGA, stock mani/O2. The Green in my sig is "on order", and wga, ported mani/hotside/o2 are going in a the same time):
http://images.puremhz.com/timing-020408.png
Inprogress Nov 19, 2007 09:45 PM
I hope I'm not out of line when I say, damn thats a lot of peak timing, is that 14* peak? And at 25psi, must make for a fun drive...
RazorLab Nov 20, 2007 12:28 AM
100 oct. Mods in sig.
http://www.norcalmotorsports.org/use...ing_042107.gif
Power chart:
http://www.norcalmotorsports.org/use...owercurves.jpg
al\lupo Nov 20, 2007 01:34 AM
Originally Posted by ShamelessCookie (Post 4973094)
OK,
http://images.puremhz.com/NLTS/HOTiming.gif
How did you work on timing map #2 and #3?
recompile Nov 20, 2007 04:43 AM
They are identical to #1
C6C6CH3vo Nov 20, 2007 04:45 AM
Razorlab, have AFR for that hex or dyno?
dudical26 Nov 20, 2007 07:56 AM
This is for 93 oct and 25psi spike holding 20-21 to redline.
(note - I changed the scaling on both axis so be aware)
http://www.skidmore.edu/~a_blaker/Misc/Timing%20Map.bmp
20psiMR Nov 20, 2007 08:23 AM
100oct, just a 25psi spike but settles to 20. Dyno sheet in sig pic thread.
http://i182.photobucket.com/albums/x246/20psimr/ecu.jpg
merkzu Nov 20, 2007 08:43 AM
Here's mine. Tuned on E78 fuel at 28 psi with buschur intake, ams fmic, gsc s1 cams, 3" tbe, walbro 255, 1000cc injectors and gm bcs
http://ws.wamnet.com/~gryan/timing.JPG
http://ws.wamnet.com/~gryan/380tq.JPG
recompile Nov 20, 2007 08:56 AM
dudical, I assume that square of 4-5° is for the two step? What benefit does that give you ?
dudical26 Nov 20, 2007 09:01 AM
12psi off the two step instead of 6-7 like stock.
matt55 Nov 20, 2007 10:29 AM
So what kind of loads are you hitting @ peak and 7.5k ? Something like 280 falling to 220 ?
C6C6CH3vo Nov 20, 2007 11:00 AM
Dont have any dyno charts yet, but last year when my 4K - 6K rpm (3rd) times were 0.3 seconds slower it was 305/304 on a MustangDyno and about 5 psi less with a wanker tune without WB. I won't guess my current #'s until I go again
http://i49.photobucket.com/albums/f264/C6C6CH3vo/h.jpg
dudical26 Nov 20, 2007 11:04 AM
That is exactly correct.
RazorLab Nov 20, 2007 11:58 AM
http://www.norcalmotorsports.org/use..._boost_afr.jpg
