-   ECU Flash (https://www.evolutionm.net/forums/ecu-flash-179/)
-   -   LoadMut 2-Byte doesn't fit with the Ignition (ROM) (https://www.evolutionm.net/forums/ecu-flash/362763-loadmut-2-byte-doesnt-fit-ignition-rom.html)
h101171 Aug 9, 2008 04:06 PM
My car:
Evo9 Stock, Tactrix Solenoid
ROM-ID originaly: EDM8840013 switched to
ROM-ID new: EDM8840016 (with no update by the Mitsu-Dealer, what is for me the only reason for that problem)
Problem:
When I log my car with Evoscan 1.35, the logged ignitions values (Map2) and the values for the the 2-Byte Load don't match with the Ignition Map2 values of the new ROM:
http://i41.photobucket.com/albums/e2..._Log6-7000.jpg
and
http://i41.photobucket.com/albums/e2...nitionMap2.jpg
Is there anybody happened the same issue? The Load seems to be fine but the value for the ignition is around 1 column left, means the ECU takes for example not the value in column "240" but from Column "220". This is competely wear.
Need help.
Marcel
mrfred Aug 9, 2008 04:50 PM
https://www.evolutionm.net/forums/sh...d.php?t=288214
https://www.evolutionm.net/forums/sh...d.php?t=307330
