ECU Swap & Immobiliser Code Issues
this one is goona be long!
i have a JDM 2006 Evo IX GSR. when i got the car i used a Evo IX GT ECU (long story) rom id - 89980000 however, because of the very few GTs a definition file was written for this rom. this caused all kinda probelms in the maps. e.g. no rev limit and random timing values :confused: as a result, i swapped ECUs to a EVO IX JDM GSR ECU in order to get the car up and running properly. rom id - 89280002. well the car did not start (as expected) because of the different immobiliser codes. as a result i flashed my old GT rom back onto the new ECU (8998000). the car is starting no probelsm but i am back to getting the same problems of no rev limit, etc. can anyone assist in changing the immo codes for me. i tried it but the car still wont start with the 89280002 rom! i just want my stock map so i can start tuning. Thanks in advance {thumbup} |
update:
just flashed my 89280002 rom back to the car with immobiliser codes - 8001 and FFFF still did not start. bump for help! if you need my roms, just let me know i will email them! |
Originally Posted by rolly1818
(Post 6542800)
update:
just flashed my 89280002 rom back to the car with immobiliser codes - 8001 and FFFF still did not start. bump for help! if you need my roms, just let me know i will email them! You have to edit the ECU periphery and disable bit 3.. |
You have to edit the ECU periphery and disable bit 3.. BTW thanks for the help on the 3 port BCS, i am installing this weekend! |
(Post 6542821)
to be honest..sounds like greek to me...
BTW thanks for the help on the 3 port BCS, i am installing this weekend! <table name="(periphery 0)" category="Misc" address="faa" type="1D" level="1" scaling="Hex16"/> Stock should be 56DA Change to 56D2 |
wat?
now its sounds like chinese....
i have no clue how to change xml files. so ur saying, go into 89280002 xml file and just add in: <table name="(periphery 0)" category="Misc" address="faa" type="1D" level="1" scaling="Hex16"/> what will be the outcome? my tuner made the GT rom (did not turn out too well) |
(Post 6542867)
i have no clue how to change xml files. so ur saying, go into 89280002 xml file and just add in: then change a value from 56DA to 56D2? what will be the outcome? my tuner made the GT rom (did not turn out too well) What the code does is disables the immobilizer unit so ANY key can start the car. If thats really your issue the code will fix it. btw enter the value in with a leading 0x so 0x56D2 |
simple enough, one last question...where do i add the table. that is where do i copy and paste the text into the xml file???
i have never done this b4. |
(Post 6542920)
1 Attachment(s)
just tried not starting!
i changed the immobiliser code to "56D2" as u asked as well. i attached my xml file so u can have a look! |
(Post 6543328)
i changed the immobiliser code to "56D2" as u asked as well. i attached my xml file so u can have a look! Not changing the immobilizer code. There should be a new spot under Misc named "(periphery 0)" Change that value to 0x56d2 |
should you not be using 8857008 on ix jdm gsr ecu?
just tried again, Thanks a million bro i owe u some :beer::beer::beer::beer:
should you not be using 8857008 on ix jdm gsr ecu? |
no 899880002 is the correct romid for a GT
