-   ECU Flash (https://www.evolutionm.net/forums/ecu-flash-179/)
-   -   What's the difference between "PATCH: NLTS + Valet + KnockCEL" and "Tephra Mods" (https://www.evolutionm.net/forums/ecu-flash/408229-whats-difference-between-patch-nlts-valet-knockcel-tephra-mods.html)
eastxcelerate Mar 21, 2009 09:13 AM
The reason I'm asking is the PATCH: NLTS + Valet + KnockCEL has my 96940011 Roms but the Tephra doesn't have it.
MR Turco Mar 21, 2009 09:15 AM
that was the original tephra mod.
Later mods only supported more common roms. if you don't specifically see your rom there is probably a version of it that is supported. Look to see if the first 4 numbers of supported roms. they are usually compatible but make sure you investigate before flashing.
eastxcelerate Mar 21, 2009 01:00 PM
OK. I know I can use the JDM Roms for 05 but that require disabling the immobilizer and I'm trying to avoid that. Beside this are all I need. I actually just need to monitor my knock without using the laptop.
voidhawk Mar 21, 2009 07:36 PM
If you want just the Cel-on-Knock, try here: https://www.evolutionm.net/forums/ec...ded-knock.html
logic Mar 21, 2009 09:41 PM
Switching from 96940011 to 96530006 no longer requires disabling the immobilizer, thanks to tephra.
Silver05Bullet Apr 29, 2009 07:37 AM
you dont have to disable the immobilizer
