help with 2 byte load for 98640014
hi, can anyone help me with a step by step on setting up 2 byte load for my evo 7 rom id 98640014, its probably very simple im just not sure on how to set it all up. thanks
This has been discussed here.
https://www.evolutionm.net/forums/ec...te-thread.html You should change your rom to 90550001 and donate to tephra :) |
yeah ive seen that thread, trouble is it doesnt tell you how to do it, only tells you what to do, not how to?
no one knows how?
You should have a MUT Table...access the table and change the values for MUT00 and MUT01 to the following:
Click Image http://img207.imageshack.us/img207/3852/39214958.th.jpg Relash the car and you should be able to log MUT 2byte Mod in Evoscan |
thanks for that, but when i open my rom there is no "mut table" would you know why that is? thanks
Make sure Ecuflash is closed and add the following code to your 98640014.xml file located in C:\Program Files\OpenECU\EcuFlash\rommetadata\mitsubishi\evo
Code:
<scaling name="Hex16" units="hex" toexpr="x" frexpr="x" format="%04X" min="0" max="65535" inc="1" storagetype="uint16" endian="big"/> Code:
<table name="MUT Table" category="MUT" address="2e9e0" type="3D" level="1" scaling="Hex16"> |
Originally Posted by R. Mutt
(Post 6992570)
Code:
<table name="MUT Table" category="MUT" address="2e9e0" type="3D" level="1" scaling="Hex16"> hi thanks for that do i add both these codes above? if so does it matter where in the file i put it. once again i appreciate your help |
1 Attachment(s)
here is my definition file if it makes it easier, thanks for your help. once the file is updated and i change the 2 values using ecuflash is that it done?
1 Attachment(s)
Yup...just reflash and you should be able to log it in evoscan.
thanks heaps, you say just reflash, but this is just the definition file so how is it flashed into my ecu, i was under the understanding the .hex file is my rom and this was just the definition file used to read it??
Originally Posted by infini_IV
(Post 6995891)
Both of you are correct. So infini IV, all you need to do now is:
1. Make sure Ecuflash is closed 2. Unzip the file I attached in my previous post and place it into C:\Program Files\OpenECU\EcuFlash\rommetadata\mitsubishi\evo 3. Open Ecuflash and change the values for MUT00 and MUT01 to the following: Click Image http://img207.imageshack.us/img207/3852/39214958.th.jpg 4. Reflash the car Can't break it down any simpler than that. You should be able to log 2 byte load from here on out. {thumbup} |
sweet, got it sorted. thanks so much i appreciate you taking the time to help me out
