help with 2 byte load for 98640014
Old Apr 26, 2009 | 01:24 AM
infini_IV's Avatar
hi, can anyone help me with a step by step on setting up 2 byte load for my evo 7 rom id 98640014, its probably very simple im just not sure on how to set it all up. thanks
Old Apr 26, 2009 | 03:55 AM
sub7's Avatar
This has been discussed here.
https://www.evolutionm.net/forums/ec...te-thread.html
You should change your rom to 90550001 and donate to tephra
Old Apr 26, 2009 | 11:54 AM
infini_IV's Avatar
yeah ive seen that thread, trouble is it doesnt tell you how to do it, only tells you what to do, not how to?
Old Apr 27, 2009 | 01:35 AM
infini_IV's Avatar
no one knows how?
Old Apr 27, 2009 | 11:40 AM
R. Mutt's Avatar
You should have a MUT Table...access the table and change the values for MUT00 and MUT01 to the following:
Click Image
Relash the car and you should be able to log MUT 2byte Mod in Evoscan
Old Apr 27, 2009 | 11:56 AM
infini_IV's Avatar
thanks for that, but when i open my rom there is no "mut table" would you know why that is? thanks
Old Apr 27, 2009 | 04:22 PM
R. Mutt's Avatar
Make sure Ecuflash is closed and add the following code to your 98640014.xml file located in C:\Program Files\OpenECU\EcuFlash\rommetadata\mitsubishi\evo
Code:
<scaling name="Hex16" units="hex" toexpr="x" frexpr="x" format="%04X" min="0" max="65535" inc="1" storagetype="uint16" endian="big"/>
Code:
<table name="MUT Table" category="MUT" address="2e9e0" type="3D" level="1" scaling="Hex16">
		<table name="X" type="Static X Axis" elements="32">
			<data>-</data>
			<data>0</data>
			<data>-</data>
			<data>1</data>
			<data>-</data>
			<data>2</data>
			<data>-</data>
			<data>3</data>
			<data>-</data>
			<data>4</data>
			<data>-</data>
			<data>5</data>
			<data>-</data>
			<data>6</data>
			<data>-</data>
			<data>7</data>
			<data>-</data>
			<data>8</data>
			<data>-</data>
			<data>9</data>
			<data>-</data>
			<data>A</data>
			<data>-</data>
			<data>B</data>
			<data>-</data>
			<data>C</data>
			<data>-</data>
			<data>D</data>
			<data>-</data>
			<data>E</data>
			<data>-</data>
			<data>F</data>
		</table>
		<table name="Y" type="Static Y Axis" elements="30">
			<data>MUT0X</data>
			<data>MUT1X</data>
			<data>MUT2X</data>
			<data>MUT3X</data>
			<data>MUT4X</data>
			<data>MUT5X</data>
			<data>MUT6X</data>
			<data>MUT7X</data>
			<data>MUT8X</data>
			<data>MUT9X</data>
			<data>MUTAX</data>
			<data>MUTBX</data>
			<data>MUTCX</data>
			<data>MUTDX</data>
			<data>MUTEX</data>
			<data>MUTFX</data>
			<data>MUT10X</data>
			<data>MUT11X</data>
			<data>MUT12X</data>
			<data>MUT13X</data>
			<data>MUT14X</data>
			<data>MUT15X</data>
			<data>MUT16X</data>
			<data>MUT17X</data>
			<data>MUT18X</data>
			<data>MUT19X</data>
			<data>MUT1AX</data>
			<data>MUT1BX</data>
			<data>MUT1CX</data>
			<data>MUT1DX</data>
		</table>
	</table>
When you open ecuflash and your rom you should see the table. If you're still confused send me your definition file and I'll add it for you.
Old Apr 27, 2009 | 10:46 PM
infini_IV's Avatar
Code:
Code:
			<data>-</data>
			<data>0</data>
			<data>-</data>
			<data>1</data>
			<data>-</data>
			<data>2</data>
			<data>-</data>
			<data>3</data>
			<data>-</data>
			<data>4</data>
			<data>-</data>
			<data>5</data>
			<data>-</data>
			<data>6</data>
			<data>-</data>
			<data>7</data>
			<data>-</data>
			<data>8</data>
			<data>-</data>
			<data>9</data>
			<data>-</data>
			<data>A</data>
			<data>-</data>
			<data>B</data>
			<data>-</data>
			<data>C</data>
			<data>-</data>
			<data>D</data>
			<data>-</data>
			<data>E</data>
			<data>-</data>
			<data>F</data>
		</table>
			<data>MUT0X</data>
			<data>MUT1X</data>
			<data>MUT2X</data>
			<data>MUT3X</data>
			<data>MUT4X</data>
			<data>MUT5X</data>
			<data>MUT6X</data>
			<data>MUT7X</data>
			<data>MUT8X</data>
			<data>MUT9X</data>
			<data>MUTAX</data>
			<data>MUTBX</data>
			<data>MUTCX</data>
			<data>MUTDX</data>
			<data>MUTEX</data>
			<data>MUTFX</data>
			<data>MUT10X</data>
			<data>MUT11X</data>
			<data>MUT12X</data>
			<data>MUT13X</data>
			<data>MUT14X</data>
			<data>MUT15X</data>
			<data>MUT16X</data>
			<data>MUT17X</data>
			<data>MUT18X</data>
			<data>MUT19X</data>
			<data>MUT1AX</data>
			<data>MUT1BX</data>
			<data>MUT1CX</data>
			<data>MUT1DX</data>
		</table>
	</table>
hi thanks for that do i add both these codes above? if so does it matter where in the file i put it. once again i appreciate your help
Old Apr 27, 2009 | 11:57 PM
infini_IV's Avatar
here is my definition file if it makes it easier, thanks for your help. once the file is updated and i change the 2 values using ecuflash is that it done?
Old Apr 28, 2009 | 09:44 AM
R. Mutt's Avatar
Yup...just reflash and you should be able to log it in evoscan.
File Type: zip
Old Apr 28, 2009 | 11:55 AM
infini_IV's Avatar
thanks heaps, you say just reflash, but this is just the definition file so how is it flashed into my ecu, i was under the understanding the .hex file is my rom and this was just the definition file used to read it??
Old Apr 28, 2009 | 12:24 PM
rob2006's Avatar
If i understand correctly and i prob dont.. lol the Definition file is like a map for your ecu, Tables in the ecu are hidden away, the info you input into the defiinition file allows you access into these tables so they can be modified.
Old Apr 28, 2009 | 01:41 PM
R. Mutt's Avatar
Both of you are correct. So infini IV, all you need to do now is:
1. Make sure Ecuflash is closed
2. Unzip the file I attached in my previous post and place it into C:\Program Files\OpenECU\EcuFlash\rommetadata\mitsubishi\evo
3. Open Ecuflash and change the values for MUT00 and MUT01 to the following:
Click Image
4. Reflash the car
Can't break it down any simpler than that. You should be able to log 2 byte load from here on out.
Old Apr 28, 2009 | 10:37 PM
infini_IV's Avatar
sweet, got it sorted. thanks so much i appreciate you taking the time to help me out
EvoPower81
May 29, 2019 11:04 AM
Jack_of_Trades
May 29, 2018 07:05 AM
Evo_Goodness
Sep 2, 2016 05:05 PM
roni4g63
Nov 14, 2015 11:45 AM
b16a95eg
May 16, 2012 07:18 PM
