Ruining in open loop for idle??
Is it possible to have the car in open loop full time while idling with a reflash. I mean being able to make the car run what is on the fuel map while the car is idling. Even after the car warms up.
Originally Posted by racer135
(Post 7065749)
Originally Posted by JohnBradley
(Post 7065861)
yeah set the open loop load and open loop throttle to 10% and voila, open loop at any rpm is possible.
Are you sure it needs a 10 on the Open Loop Throttle???? |
(Post 7067342)
There are two open loop load tables and two open loop throttle. Whats the difference between them. Ths scale of Open Loop Load is on % and Open Loop Throttle is in Volts.
Did this work? Setting it all to zero?
On the 3rd gen eclipse forum, one of the guys was saying that since its in LOAD, he changed it to throttle position. However, I don't see throttle position as something you can change the value to; I only see Throttle Voltage, but I guess you can do it a number of ways to get it to go to open loop. Edit: Turns out he mean Throttle Voltage. |
Originally Posted by itzthadre
(Post 7117342)
On the 3rd gen eclipse forum, one of the guys was saying that since its in LOAD, he changed it to throttle position. However, I don't see throttle position as something you can change the value to; I only see Throttle Voltage, but I guess you can do it a number of ways to get it to go to open loop. Edit: Turns out he mean Throttle Voltage. I did notice a distinct difference in low load cruise and idle AFRs just from driving and eyeballing the gauge, so I think it worked from what I've checked out so far. {thumbup} Wild guess says that throttle voltage is like our TPS. |
(Post 7065861)
http://evoecu.logic.net/wiki/Periphery_Configuration |
Originally Posted by RoadSpike
(Post 7122016)
Wouldn't it be easier to just set the periphery (FAA) bit 4 to 0? That would force open loop all the time regardless of rpm or load.
(Post 7122016)
(Post 7122179)
I am looking for open loop only while idling not for cruising.
just a question here. by forcing the car in open loop 24/7 do you still need to scale injectors? since the car will be reading for the table for the desired AFR?
Originally Posted by rolly1818
(Post 7122998)
The extra fuel problem is only going to get worse with higher load and rpm you're just doing ALOT more work by not scaling the injectors. |
Yes... The extra fuel problem is only going to get worse with higher load and rpm you're just doing ALOT more work by not scaling the injectors. |
