High idle and I'm totally stumped
I'm pretty stumped here, so I thought I'd ask you guys for your expertise. My car idled fine, I switched out the stock injectors for FIC 1450's and had it tuned, and now I can't get it to idle any less than 1500 rpm. The biss screw is all the way bottomed out and it is still idling at 1500 rpm. My tuner suspects that my ported throttle body has an undersized butterfly, but my problem with that theory is that the car has idled fine after it was installed. I thought there must be a boost leak somewhere in the intake manifold, but I pressurized it to 40 psi today and didn't find any leaks. My next step would be to load the stock tune and put the stock injectors back in to see if the tune is the problem.
Anyways, I was wondering if you guys could take a look at my .rom file and see if you see anything obvious befor I do that? Thanks. I tried attaching the .rom, but it says invalid file, so I guess I'll have to email it. |
Originally Posted by dsevo
(Post 7372825)
{thumbup}
Thanks for having a look guys. I get all the mechanical stuff, but I just don't really have a clue on the computer stuff.
Resolved I hope
can u post what was the fix??
Originally Posted by rolly1818
(Post 7373207)
I'm at work so I cant try it out just yet. I'll post in the morning after I have a chance to look at it. A couple guys on here had a look and gave some pointers, so hopefully it will be fixed tomorrow.
I have a related question, can the front o2 affect idle and if it isn't working will the car idle high? I don't know whether its broken or not, but I know it is really close to the AC compressor because of my turbo, so it is a possibility that is isn't working. |
BTW, thanks Todd and Cory for taking a look. EvoM is a wealth of knowledge because people like you guys are willing to help othe rpeople out.
(Post 7373265)
(Post 7373270)
Cory |
Originally Posted by EVOIXreno
(Post 7373255)
His Desired Idle is a little high in all tables.. he is going to lower it and get back to me.
(Post 7373265)
Well I made the changes, and the idle is exactly the same. Something is definitely not right, but I'm not sure what. Before I have you guys go on a wild goose chase I am going to swap out the injectors for the stock ones and put the stock tune back in to see if it is still idling high. If it isn't I know it's something in the computer, otherwise its something mechanical. Thanks for your help guys, I'll keep you posted.
BTW, I logged "Oxygen Sensor" and it is all over the place just like you said, so I don't think there is a problem there. |
^^^ You have to be ****ting me!!!{thumbdwn}
| All times are GMT -7. The time now is 05:11 AM. |
