New help finding some maps in two ROMS
First I need to find the "low coolant temp timing trim map" for ROM 96420008
And I need the "decel fuel cut" maps for ROM 96940011 I have searched for hours, and still cant find the addresses for those tables in those ROMs. Here is a link that discusses those tables for other ROMs https://www.evolutionm.net/forums/ec...evo-7-9-a.html |
It looks like this is what you want for 96420008:
Code:
<table name="Low Coolant Temp Timing Trim Map" category="Timing" type="3D" level="2" swapxy="true" scaling="TimingTrim8" address="3ff5"> Code:
<table name="Decel Fuel Cut Delay #1" category="Fuel" address="3972" type="2D" level="2" scaling="uint8"> |
Thank You happen to know the EGR timing maps for ROM 96420008? |
Do you have the scaling for "timingtrim8"
The scaling is from evo7base_20081101.xml:
Code:
<scaling name="TimingTrim8" units="units" toexpr="x-128" frexpr="x+128" format="%.0f" min="-128" max="128" inc="1" storagetype="uint8" endian="big" /> For 96420008's EGR timing tables, it looks like this is it: Code:
<table name="High Oct EGR-Enabled Advance" category="Timing" type="3D" level="2" swapxy="true" scaling="Timing" address="3e6d"> (And don't thank me yet, make sure they look right/work right first. ;)) |
nevermind
Originally Posted by logic
(Post 7524311)
Code:
1 Attachment(s)
What about these for 9694001? Do they look right?
https://www.evolutionm.net/forums/at...1&d=1253456188 |
1 Attachment(s)
Ah, yes, sorry about that; I didn't look up the load axis on those 2D tables; that's what I get for cutting and pasting. ;) Looks like your pick is off by one; try the address "5d52" for the load axes, and "594e" for the Engine Speed axis on the Decel Fuel Cut Retard table. (I updated the original post.)
Hey logic, do you have the maps for "decel fuel cut" for the 96420008 ROM?
This looks like it for 96420008:
Code:
<table name="Decel Fuel Cut Delay #1" category="Fuel" address="42bc" type="2D" level="2" scaling="uint8"> |
okay, thanks.
(Post 7524286)
Code:
<table name="Decel Fuel Cut Delay #1" category="Fuel" address="3972" type="2D" level="2" scaling="uint8"> Do you have the info for #2 and #4 for the 96940011, even if they look like duplicates? |
No, I mean #2 and #4 appear to reference the exact same tables as #1 and #3 (ie. same ROM addresses). It's kind of a messed up situation, and will probably force me to actually read the code for sub_CC6 and sub_C28 and figure out how the heck that table gets parsed.
I could be misreading this, though, which is why I'd love someone else to take a quick peek. l2r99gst, if you're reading this, are you still even remotely interested in 96940011? ;) Also, it looks like I might have been wrong about the Engine Speed axis for Decel Fuel Cut Retard; the address is actually 5a22, not 594e. (Not that it matters, unless you're planning on rescaling it, since the values are the same, but better to be accurate.) Again, I've re-edited my post to reflect the correct value. |
