7 ECU -> 6.5 Car (EGR + EVAP CEL's)
Hi Guys,
I have a friend that is getting: P0433 evap system purge control valve circuit. P0403 EGR solenoid. He has a 7 ECU in a 6.5 Evo, he is running 99860003 as his ROMID. As the fix is it correct to change bit15 of Periphey2 (0xFCA) to 0? This wont affect WOT fueling or anything will it? Just checking :) Cheers D. |
shouldnt cause any problems with WOT fuelling.enter 0x0a89 in perephery 2
tell him to use 90550001 its a ralliart rom JDM and has most of the error codes disabled I sent ya a basemap copy I use for earlier evo conversions and definition
{thumbup} or set perephery FAA to 56D0 its the 3rd bit on the high byte to disable egr |
interesting, 56D0 also turns off the immobiliser. Dave, I just usually turn the whole of FCA off and havent had any complications.
thanks doodz :)
6 doesnt have immobiliser
Originally Posted by todd6027
(Post 7578199)
I am not surprised they dont, its just that hex bit turns the immobiliser off and thats the only thing I saw mapped on that one. I didnt realise it affected the EGR as well, I'll have to look closer at the periphery map worksheet I guess.
Originally Posted by JohnBradley
(Post 7581308)
iirc changing FCA from 0x8A89 to 0x8D89 will stop the EGR fault code
btw never seen rom id 99860003 |
Originally Posted by evonut270
(Post 7581043)
no but some 7 ecus have them ;)
| All times are GMT -7. The time now is 03:55 PM. |
