which parameter need to log to use with maptracer
hi. my car is evo 5 jdm i can read and write flash normaly. as i understood to log knock i must log rpm , knock sum and some 3-rd parameter (something meens load) to have posibility using maptracer. my question is which one i must log ? thanks ! p.s when i am trying to log load calculated it always stays 0. please help :)
when tuning WOT i use TPS (to know when i floor it), rpm, knock, afr, timing, load . i only use idc and ipw when i turn up the boost to make sure im not on the edge of the limits of the injectors.
map tracer for evoscan 2.6 would like load calc logged to display a trace. but since its limited to i think 160 load? then you need 2byte or 1byte load to read higher |
ok thanks for reply!. as you sad i must log load 1byte but i can not make this working. i think need to edit rom to add abylity log load1byte (tephra mod i gues) but how to do ic jus coping xml files to xml folder does not helped me. need advice.
your running a ev0 8 ecu in a evo 5? which rom are you using?
no i am runing stock evo5 ecu with stock evo 5 rom . case id : mr4200403 internal id :22580007
Originally Posted by ms_logging
(Post 8306102)
please some one help me to make map tracer work...
Evoscan 2.6 needs rpm and load calc those are the only 2 parameters it need 2 enable map tracer. Evo scan 2.7 need I beleave 2byte rpm and 2byte load I think...
but how to enable 2 byte load logging .
Pm ceddy . He specializes in the older ecus so may be he can whip up a code for you of basic mods. So far I've searched and can't find any disassemblies for pre evo7. But hopefully some one can help.
1 Attachment(s)
thanks for helping me ! i will attach my rom maybe someone can patch it to give me posibility of logging load propertly . :)
any ideas ?
Only newer versions of EvoScan work with H8(Evo5-6.5) MapTracer.
Think version 2.7.0031 and above work. Any of the Loads will work, but "ECULoad" maxes out at 160 (about 9 psi). You will need to add a 2Byte Load. For 22580007 the addresses for 2Byte Load is F196 and F197. In MUT Table change MUT00 to F196 and MUT01 to F197. Then log "Load MUT 2Byte Mod" in EvoScan. 2Byte Load has no upper limit. http://geekmapped.com/ is a good forum to check out, they specialized in older Evo ecus. And you may want to switch to a rom with more support. |
thanks ! but now i got another problem. evoscan 2.6 logging duty cycle normal but evoscan 2.7 always idicates 0. pulse wight indicated normaly.
1byte will work too
in evoscan right click on load1byte and click edit data item where it says Log reference: Load1b change it to Loadcalc now when you do a log of 1 byte map tracer will find it by looking for loadcalc which you just called {thumbup} or do the same with 2byte if your logging that |
