-   ECU Flash (https://www.evolutionm.net/forums/ecu-flash-179/)
-   -   P0462 code - can't clear :/ (https://www.evolutionm.net/forums/ecu-flash/506425-p0462-code-cant-clear.html)
TJung Jul 29, 2010 09:59 PM
Hey. I was set my periphery FDA bit 11 to 0 and still nothing. P0462 code is still showin'.
Any ideas ?
german_evoVII Jul 30, 2010 03:56 AM
having the same problem here.
I am running an 88591715 V7 SD rom on the EDM Ecu.
Since we doest have the Fuel level senders attached to the ecu, this error will show up every engine start.
wiring in the senders doesnt solve that, because the EDM Ecu doesnt have these pins connected inside. ( reading is always 0 , i tried that, Pins 95 and 97 )
If anybody from the ECu Gurus has an option to patch that ( so that the routine for emmisions read half full all the time ) that would be perfect
Steffen
TJung Jul 30, 2010 05:02 AM
I have 88590015 with v 5.10, but my car doesn't have few sensors, that are in stock Evo (engine works great btw, but I wish to have no cel)
TJung Jul 30, 2010 11:35 AM
Really no one can't help ? :(
german_evoVII Jul 31, 2010 11:36 AM
I traced down the ECU Pins 97 and 95 ( USDM Fuel level inputs )
In the EDM Ecu ( 88840013 - 17 ) the 2 pins are open.
There are missing a few parts ( have the ECUs side by side )
Its actual an resistor and some caps. so i will try to figure that out, so we can modding EDM Ecus to an static Fuel level so the Ecu is happy.
it would be much easier to have an patch to make that by software ( its only a different pointer to an fixed address, so no big deal.
Steffen
TJung Jul 31, 2010 11:44 AM
I just wonder why it wont turned off by setting FDA bit 11 to 0 ?
german_evoVII Jul 31, 2010 12:10 PM
maybe its an separate bit for the 462 and 463 Celīs ( which isnt found until now )
Since nobody runīs an USDM map at an edm Ecu, it isnt a high priority issue
acamus Jul 31, 2010 12:14 PM
Maybe you can wire in some resistors, that would keep ecu happy (2,5V at pin)?
german_evoVII Jul 31, 2010 02:47 PM
Thats what i will try, but i have to tracedown the board a bit more.
The USDM Ecu has a few Chips, resistors, Caps more than the edm.
I dont want to fry the ECU.
What i found is: The EDM Ecu with 88591715 is giving back with MUT 88 app.0.06 volts at idle and app 1 Volt when outside the Idle.
So, since the software is USDM, there should be always a 0.0xx at the Processor pin and reading should be match that.
The reading is maybe an different source on the Board itself or an other pin feeding the voltage by a solder joint.
Best solution would be an 88841717 working version, so we do not lost the GearBox temp sensor ;-)
I am not a coder, but i am an electronics specialist and Engine Builder.
I will find a solution to get it run as i want it.
el.guerrero Aug 14, 2012 11:17 AM
no one news about it?
The 88590715 is more improved , 88580715 less :(
I also have this code in my evo.. and no way to shout it.
211Ratsbud Aug 14, 2012 02:25 PM
What about obd circuit bypass did you try that?
el.guerrero Aug 15, 2012 06:26 AM
what do you mean?
211Ratsbud Aug 15, 2012 09:27 AM
https://www.evolutionm.net/forums/sh...d.php?t=547645
el.guerrero Aug 16, 2012 04:49 AM
ehi 211ratsbud thanks a lot, you very gentle.
News coming!
yoyojimmy Jan 4, 2014 07:42 AM
Originally Posted by german_evoVII (Post 8543172)
I traced down the ECU Pins 97 and 95 ( USDM Fuel level inputs ) In the EDM Ecu ( 88840013 - 17 ) the 2 pins are open. There are missing a few parts ( have the ECUs side by side ) Its actual an resistor and some caps. so i will try to figure that out, so we can modding EDM Ecus to an static Fuel level so the Ecu is happy. it would be much easier to have an patch to make that by software ( its only a different pointer to an fixed address, so no big deal. Steffen
hi. I have this issue yet.do u find out the way to get rid of p0426?
