-   ECU Flash (https://www.evolutionm.net/forums/ecu-flash-179/)
-   -   Can't won't start help?! (https://www.evolutionm.net/forums/ecu-flash/534489-cant-wont-start-help.html)
5LEEPERISAH23I Jan 15, 2011 03:53 PM
So just did a 2.1 build, my car will crank , it is getting fuel n spark but will not start..
I live in PA so it is 18-34 degrees out , just did a 2.1 build n this problem has been a problem since..
What it isn't is the cam angle sensor.
This is the weird part when it is warm the motor it starts up every time. N it starts up cold onces in a blue moon
Could I change somthing in ECU flash to make cold start up better
AlwaysinBoost Jan 15, 2011 04:18 PM
did you switch ROM's since the motor swap? if so,try to disable the immobilizer and see if that works.
5LEEPERISAH23I Jan 15, 2011 04:57 PM
Didn't switch ROMs
4RETECH Jan 15, 2011 05:58 PM
So, you got the oil pump stuff back on?
Timing good, and leakdown checked out, no bent valves??
Fuel and spark, but compression is needed.
5LEEPERISAH23I Jan 15, 2011 07:10 PM
Everything u listed is good.. I'm thinking it is the start up cold crank setting on ecu flash .. Now what it should be around
