Can't won't start help?!
Old Jan 15, 2011 | 03:53 PM
5LEEPERISAH23I's Avatar
So just did a 2.1 build, my car will crank , it is getting fuel n spark but will not start..
I live in PA so it is 18-34 degrees out , just did a 2.1 build n this problem has been a problem since..
What it isn't is the cam angle sensor.
This is the weird part when it is warm the motor it starts up every time. N it starts up cold onces in a blue moon
Could I change somthing in ECU flash to make cold start up better
Old Jan 15, 2011 | 04:18 PM
AlwaysinBoost's Avatar
did you switch ROM's since the motor swap? if so,try to disable the immobilizer and see if that works.
Old Jan 15, 2011 | 04:57 PM
Didn't switch ROMs
Old Jan 15, 2011 | 05:58 PM
4RETECH's Avatar
So, you got the oil pump stuff back on?
Timing good, and leakdown checked out, no bent valves??
Fuel and spark, but compression is needed.
Old Jan 15, 2011 | 07:10 PM
Everything u listed is good.. I'm thinking it is the start up cold crank setting on ecu flash .. Now what it should be around
jheff
Jan 10, 2017 07:07 AM
W1NST0N
Lancer Troubleshooting
May 8, 2014 02:16 PM
Exige90
Mar 3, 2014 06:59 PM
d3r3k
Jul 12, 2010 07:20 AM
black evil evo
AEM EMS
Oct 25, 2005 02:34 PM
