05mr cant read rom
Well i got my tractrix cable the other day and finally got around to messing with the car and i when i hit read from ecu it goes thru everything but at the end it says unable to read rom whats going on ?? i saved the file but i dont know what else to do any help would be greatly appreciated!!:thumbup:
did you buy the car new? has it ever been tuned?
no i bought it used i buy and retail cars and i decided to keep this one. Car has been modded a good bit so im guessing it has been tuned b4 but not sure of what i can do im going to look in the sticky section about the cant read rom as well and see if i can find anything in that area
if i try to open the rom i saved when i attempted it the first time it says" Unknown ROM image in a popup box
it probably has a different xml loaded to the ecu.
What do i need to do?!?!
Try putting in some of the tephra xml's into the rommetadata folder in ecuflash. Just download the xml pack in the tephra threads. Check 'important ecu threads' sticky and you will find them there under the tephra threads.
ok i will try this and test it later
also how do i go about adding more xmls?
https://www.evolutionm.net/forums/ec...ead-links.html
search... learn... just about everything you could ask about tuning will be answered by something in this link... |
yeah thats wat im doin and still see nothing lol starting to regret it lol
Originally Posted by mtm864
(Post 9161698)
When the error comes up select continue and give us the rom ID number in the rom info segment inside the left hand box. |
all it says after i try to read file from ecu that t here is no definition for it and gives me 3 options 1 abort and 1 continue usinfing no definition and one for developers only. And in the left hand box everything is blank exceptmemory model number which is SH7052
(Post 9162164)
Nope nothing after that
