1 byte logging wrong values
3 Attachment(s)
Hello guys, im again here with a question :)
my 1 byte logging is showing wrong values at wot. Attached is the logs, i checked my mut tables (Mut41 value is 840B) and they are true, also evoscan formula is 1.2 . What could be the problem ? Thanks for any help |
Which Tephra rom are you using?
Originally Posted by HyperDisorder
(Post 10035461)
Does 2byte load log correctly?
Originally Posted by Boosted Tuning
(Post 10035524)
Originally Posted by canberkd
(Post 10035529)
I didnt log 2 byte so i don't know if it is logging correctly
(Post 10035559)
Well give it a try. {thumbup}
any reasons why 1 byte is logging wrong values? |
(Post 10035603)
Okay, ill give it a try and post the results,
(Post 10035629)
I dont have any ideas yet. Thats why I would like to see what 2byte load says.
Thank you |
1 Attachment(s)
Adjusted my mut tables and logged 2 byte load today,
2 byte is showing very high values, goes up to 350 as seen in logs. Any helps? What can be done ? |
(Post 10041918)
(Post 10042071)
You need a higher 1byte factor. That is your issues. Raise it to 1.5 in your ROM AND in EvoScan. {thumbup}
(Post 10042820)
should i have to change the "2 byte to 1 byte load factor" in my rom ?
1 Attachment(s)
(Post 10042862)
Yep, in the ROM and in the formula for "1byte Load" in EVOScan.
(Post 10043183)
changed those factors to 1.5 and here is a 3rd gear wot log. 22 psi peak boost but again very high values for load.
Dont worry about how much load you have. If its too much for your tables, then rescale your load axis or move to Tephra V7 with BIGMAPS. Now you can log just 1byte load. |
