88770005 xml needed !!!! please help
does anyone has correct xml for 88770005 ? ( Evo 9 GT wagon 6 speed )
I really need it, cuz i couldn't read my rom properly because the one that i have, it messed up and not correctly xml if anyone has it please let me know as soon as possible or you could email me xml to LTHANAKRITL@GMAIL.com Thank you in advance !!!!!!{thumbup} |
Should be in your email inbox now. It's not a great definition but it does give you the essential tables.
I am wondering why you need a definition for a wagon ROM? |
Thank you! I'm in Thailand now. And try to read all table. For now timing map, fuel map, are fine. But im going to use 3 port which i need to use Max wastegate table but the table value are not line up like what it should be. Dont u have to complete one?
anyone else ?
88770005 xml should include 89960000 which inherits evo9 base e mail sent
Originally Posted by monkeyevo
(Post 10781763)
I'm still running the stock setup boost solenoid (twin 2 ports), hitting around 23psi at redline and still climbing (logged through JDM MAP sensor). Unfortunately my car was tuned by a local tuner here using ECUTEK, which has a very good definition for the wagon ROM. Unfortunate because ECUTEK does not allow public use of their software. If you find the correct addresses for boost control, can you let me know? I need to adjust my WGDC and reduce my boost a fraction. |
^^^ I will for sure thank you for your help again, I might just use E-boost control instead of 3 port then
Thank you again |
Wastegate Duty Cycle tables are at:
3BAC 3BC2 3BD8 3BEE 3C04 3C1A 3C30 Boost Target load tables are at:: 3C46 3C5C 3C72 3C88 the RPM axis is at 65F2, 16 element tables. |
Originally Posted by merlin.oz
(Post 10784710)
3BAC 3BC2 3BD8 3BEE 3C04 3C1A 3C30 Boost Target load tables are at:: 3C46 3C5C 3C72 3C88 the RPM axis is at 65F2, 16 element tables. In the XML there is <!-- *** Turbo Wastegate Control, Single Solenoid *** -->, I'm using a twin 2 port solenoid setup, which I thought was a stock JDM setup. Is this XML definition not suitable for my solenoid setup? If I'm good to use these tables, how would I adjust to reduce my boost a little? (I'm getting boost creep till it hits fuel cut, near the top end). http://imageshack.us/a/img442/1898/mwdcandbdel.png |
^^ I'm getting the same table above :(
(Post 10784710)
1 Attachment(s)
Originally Posted by todd6027
(Post 10787139)
hi merlin do you have the addresses for boost error correction
https://www.evolutionm.net/forums/at...1&d=1367709900 |
Originally Posted by AndyCT9W
(Post 10792412)
The address in the XML written by Merlin has the address 3B94 and returns the following table in my ROM:
https://www.evolutionm.net/forums/at...1&d=1367709900 i can get the other tables to display correctly with merlins addresses but only with ecuflash v 1.44.3719 |
(Post 10792809)
whats address for y axis boost error .
i can get the other tables to display correctly with merlins addresses but only with ecuflash v 1.44.3719 Interesting that it only displays correctly in a certain version of ECUFlash, I open it in that version and post back. Cheers. |
Right, I've downloaded ECUFlash 1.44.3719, done a bit of mucking around with rommetadata locations (only because I've mucked around with them previously for some weird issues I was having a while ago). And now I get the following tables:
http://imageshack.us/a/img843/4192/mwdcbdelbec.png Much much better, it's quite relieving to finally have a a good definition opening properly after looking for so long. Thanks for the help Todd. {thumbup} |
