v7 omni4 bar set up help...
So I just installed my Omni 4 bar map in my car, then I used the rom file from the V7 page for 94170715 V7+Omni 4bar and switched over my tune. Now every time I turn the car off and back on I Throw a code for P0403 Exhaust Gas Recirculation Circuit Malfunction and I have a feeling something isn't set up right. I have no map scaling options or anything like that. I also cant figure out the Psi based boost control. Any help is very appreciated Thanks Ps the car runs fine.
Originally Posted by jmac13
(Post 10788223)
I can take a look at your rom if you want and XML file. You can send it to puredriveperformance@gmail.com |
im not sure the egr code is related to the missing scalings. i finally loaded my tephra map last week and has the same thing happen. but it looked like i had not matched one of the EGR related periphery bits against my old rom. did you check those?
Originally Posted by PureDrivePerformance
(Post 10788267)
There is an option. You can search for the Omni 4 bar sensor settings. You many need to add XML to be able to see it.
Originally Posted by killerpenguin21
(Post 10788276)
You most likely missed one of the bits, just disable it. I think its in the fca bits.
The guide I wrote should help you figure out PSI-based boost control. The link to it is in my sig.
Originally Posted by boosted91t
(Post 10788967)
FAA bit 11 = 0
FCA bit 9 = 0 thats what killed the code for me. i had missed FCA bit 9 initially. |
