v7 omni4 bar set up help...
Old May 1, 2013 | 08:47 PM
jmac13's Avatar
So I just installed my Omni 4 bar map in my car, then I used the rom file from the V7 page for 94170715 V7+Omni 4bar and switched over my tune. Now every time I turn the car off and back on I Throw a code for P0403 Exhaust Gas Recirculation Circuit Malfunction and I have a feeling something isn't set up right. I have no map scaling options or anything like that. I also cant figure out the Psi based boost control. Any help is very appreciated Thanks Ps the car runs fine.
Old May 1, 2013 | 09:22 PM
PureDrivePerformance's Avatar
There is an option. You can search for the Omni 4 bar sensor settings. You many need to add XML to be able to see it.
I can take a look at your rom if you want and XML file. You can send it to puredriveperformance@gmail.com
Old May 1, 2013 | 09:30 PM
killerpenguin21's Avatar
im not sure the egr code is related to the missing scalings. i finally loaded my tephra map last week and has the same thing happen. but it looked like i had not matched one of the EGR related periphery bits against my old rom. did you check those?
Old May 2, 2013 | 09:20 AM
jmac13's Avatar
I will try and send that off when I get off work today. Thank you.
Old May 2, 2013 | 09:22 AM
jmac13's Avatar
I'm pretty sure I matched them all up but I will double check this afternoon.
Old May 2, 2013 | 09:26 AM
boosted91t's Avatar
You most likely missed one of the bits, just disable it. I think its in the fca bits.
Old May 2, 2013 | 10:04 AM
Raptord's Avatar
The guide I wrote should help you figure out PSI-based boost control. The link to it is in my sig.
Old May 2, 2013 | 06:26 PM
jmac13's Avatar
I did disable it and it still pops up.
Old May 2, 2013 | 09:59 PM
FAA bit 11 = 0
FCA bit 9 = 0
thats what killed the code for me. i had missed FCA bit 9 initially.
browningderek
Sep 11, 2025 05:32 AM
JDavenport
Jun 14, 2013 09:47 AM
BooHAHA
Feb 21, 2012 03:22 PM
Dreadevo9
Dec 4, 2011 07:37 AM
