Did my first log
Old May 2, 2013 | 11:33 AM
aggieEVO's Avatar
Did my first log
I'm having some issues with my laptop and with EvoScan in general. If I restart the computer it has trouble connecting up and I have to restart. Says it can't find certain files. I'm going to try to use a different laptop later.
Also attaching my log.
Things I've noticed:
TPS is at 96.x%. I guess I need to adjust.
I didn't have as much knock as I thought I would, but it's also just one pull. I'll try to get several in later.
Mods:
Rewired Walbro 255
Perrin MBC at around 18psi.
TephraMod V7
Can't log boost, yet, and I didn't feel it was worth logging A/F without a wideband.
Thoughts or suggestions?
Crap, you can't attach a .csv?
Old May 2, 2013 | 11:52 AM
STLEVOIX's Avatar
why 18PSI?
Old May 2, 2013 | 12:01 PM
aggieEVO's Avatar
I asked around and was told it was safe to run with everything else stock.
Originally Posted by STLEVOIX
why 18PSI?
Old May 2, 2013 | 12:26 PM
Boosted Tuning's Avatar
Stock is 19psi and you can up it a couple psi.
Old May 2, 2013 | 12:33 PM
foxbat's Avatar
You can attach csv files in zip files.
Don't start tuning without having a wideband kit to log AFR.
Make sure that the car has no boost leaks.
You could tune the car without having to log boost.
If properly tuned, you could run higher boost (25-26psi) especially if using 93 or higher fuel.
Old May 2, 2013 | 12:37 PM
aggieEVO's Avatar
Thanks guys, I may leave it where it is for a bit. I still have a dirty stock filter in the airbox. I'm going to replace that before I crank the boost at all.
I haven't done a boost leak test, yet, but I'm hoping to build a tester soon.
I'm not planning to tune until I get a wideband, that's one of the first things on my list. Just trying to get a feel for logging.
I'm running 93.
I did 2 more pulls. My only substantial knock is down low in the same spot that's shown in this log.
It just started raining. No more pulls today on crappy tires
Old May 3, 2013 | 07:38 AM
aggieEVO's Avatar
Glad I got TephraMod on yesterday. Getting some knock in strange places. 5th gear mid RPM part throttle. I guess it's during spool. I'll be careful there until I can figure it out.
Old May 3, 2013 | 07:43 AM
evo8426's Avatar
Is there any reason as to why you rewired the Walbro? - EDIT: Never mind, I read through your build thread and seen the previous owner did it.
The easiest way to post up logs is to use winzip and then attach the file into a post.
Old May 3, 2013 | 12:34 PM
aggieEVO's Avatar
Yeah, he was running an EF3, I think. Guess he needed a little more fuel.
UxC
Dec 19, 2016 08:43 AM
danike
Apr 22, 2014 03:52 AM
SudzRA
May 18, 2011 09:28 AM
Mellon Racing
Dec 18, 2007 07:19 PM
Titanium
Apr 3, 2007 04:24 PM
