flame doesn't emerge when launch map in operation
2 Attachment(s)
2006 edm evo9
88840017 -88590714 v7 Step on the clutch flame doesn't emerge when launch map and boost only has 7psi!:eek: Where is wrong? Thank you very much |
The timing in your log is still in the 15-20 range, not in the negatives like your launch map has. Seems like your launch map isn't activating.
1 Attachment(s)
Originally Posted by Raptord
(Post 10957039)
could you like to give me any suggestion? |
what is your launch map tps set to? It looks like 90% in your picture but kinda hard to see, if so then you didn't get into the launch maps because you only went 70% throttle in that log.
Originally Posted by 90zcrex
(Post 10957642)
I immediately to test! |
:mitsu:Please correct me if i'm wrong but i think Evos have fuel cut, so there is almost no extra fuel to burn when launching. Could this be part of your problem?
You're correct in that the evo uses fuel cut rather than ignition cut, however there's still enough fuel for pops, bangs and flames with an aggressive launch map. The issue here is that the OP's launch map TPS threshold is 90% but he's only going up to ~70% TPS, so launch maps never get activated.
(Post 10961363)
| All times are GMT -7. The time now is 06:09 AM. |
