flame doesn't emerge when launch map in operation
Old Sep 13, 2013 | 09:40 AM
kubaolong's Avatar
2006 edm evo9
88840017 -88590714 v7
Step on the clutch
flame doesn't emerge when launch map and boost only has 7psi!
Where is wrong?
Thank you very much
Attached Thumbnails flame doesn't emerge when launch map in operation-lc.jpg   flame doesn't emerge when launch map in operation-lc2.jpg
Old Sep 13, 2013 | 09:48 AM
Raptord's Avatar
The timing in your log is still in the 15-20 range, not in the negatives like your launch map has. Seems like your launch map isn't activating.
Old Sep 13, 2013 | 07:07 PM
kubaolong's Avatar
thanks for your reply .Raptord!
could you like to give me any suggestion?
Attached Thumbnails flame doesn't emerge when launch map in operation-lc3.jpg
Old Sep 13, 2013 | 07:39 PM
90zcrex's Avatar
what is your launch map tps set to? It looks like 90% in your picture but kinda hard to see, if so then you didn't get into the launch maps because you only went 70% throttle in that log.
Old Sep 13, 2013 | 07:56 PM
kubaolong's Avatar
thanks for your reply .90zcrex. It is 90%.
I immediately to test!
Old Sep 17, 2013 | 05:05 PM
VIIIdriver's Avatar
Please correct me if i'm wrong but i think Evos have fuel cut, so there is almost no extra fuel to burn when launching. Could this be part of your problem?
Old Sep 17, 2013 | 05:10 PM
Raptord's Avatar
You're correct in that the evo uses fuel cut rather than ignition cut, however there's still enough fuel for pops, bangs and flames with an aggressive launch map. The issue here is that the OP's launch map TPS threshold is 90% but he's only going up to ~70% TPS, so launch maps never get activated.
Old Sep 18, 2013 | 06:48 AM
VIIIdriver's Avatar
Thanks for the explanation
eTiLiKo
May 23, 2024 01:45 PM
project_skyline
Jun 26, 2017 02:00 PM
evojmj85
Lancer Troubleshooting
Dec 28, 2015 08:46 AM
ant_turbo
Nov 19, 2010 05:55 AM
3gEclipseTurbo
Jan 5, 2010 04:46 PM
