Evoscan full trims help
Old Sep 17, 2013 | 06:03 AM
nicolassabra's Avatar
EVOSCAN fuel trims need help
hello i want to check if i'm logging proper fuel trims or they are just stuck on the same values all the way
File Type: zip
Old Sep 17, 2013 | 07:30 AM
domyz's Avatar
You are logging the right ones. They should adjust themself at about every 10minutes if needed.
Did you mess with "Closed loop - LT trim control table" ?
Old Sep 17, 2013 | 07:42 AM
no i left it the way it was originally on tephra v7
Old Sep 17, 2013 | 11:40 AM
so if am reading proper fuel trims i need to re-scale my maf ?
THANKS IN ADVANCE
Old Sep 17, 2013 | 03:47 PM
domyz's Avatar
THANKS IN ADVANCE
You mid trim is okay, low trim need some tuning. And yes you could adjust MAF compensation but you're playing with load which is related to many other variables and tables. I suggest (consensus) that you reduce injector latency. Reduce it a little bit and test.
Old Sep 17, 2013 | 11:56 PM
SO u don't suggest decreasing my m MAF scaling table values by 9% from 19 hz till 1610hz without messing with maf compensation and injecor latency?
Old Sep 18, 2013 | 08:49 AM
domyz's Avatar
I'm not sure where your 9% come from?
And as I said you don't need to reduce MAF scaling unless you really need to rescale your MAF for a new intake or an issue. If you adjust MAF scaling you'll play with load variable which is related to fuel calc. The little problem (if any) is that load is also related to timing, many compensations, many subroutines.
The best way to adjust trim is by only affecting the fuel variable. This is where injector scaling and latency values come into play.
Your low trim is -6,8 and mid is -0,78. I suggest that you reduce latency a little bit at the time and see what happens to your low trim. Keep an eye on STFT while doing that.
Think of it like this:
If you reduce latency, ECU will say ok my injector react faster so I need to open injector for a shorter amount of time ( result is less fuel )
If you reduce injector scaling, ECU will say: my injectors are smaller so I need to open them a longer time ( result is more fuel )
Latency is the injector reaction time when signal is sent. This variable will theorically affect all loads, but it will only be perceptible at very low loads, when ECU injects a little amount of fuel. Effect on WOT fueling is like adding a single glass of water in a lake: AFR will remain quite the same. But add this same glass of water in a bottle, final AFR will be much more changed.
Scaling will affect all fueling situations. Rescaling injectors often mean readjusting latencies.
Old Sep 18, 2013 | 11:45 AM
Thank you sir for help and time i really appreciated
LCS
Sep 25, 2015 01:48 PM
nicolassabra
Sep 19, 2013 04:02 AM
MrJuls
Feb 29, 2012 09:32 PM
EvoTech
Apr 11, 2011 11:07 PM
