How to remove radio/storage trim on Evo IX
Old Feb 28, 2012 | 11:13 PM
MrJuls's Avatar
How do i remove this trim to get behind the console?
Old Feb 29, 2012 | 01:04 AM
boostless's Avatar
You should be more specific. Are you talking about the lower cubby hole? If so, remove the two screws on the "roof" of the hole and firmly pull it toward you.
Old Feb 29, 2012 | 01:42 AM
2hot2handle's Avatar
pull the climate control knobs off. unscrew the 2 screws. pull from the bottom and work your way up. dont be afraid to give it a solid pull. the bezel is strong.
Old Feb 29, 2012 | 02:13 AM
MrJuls's Avatar
Yes,i mean the radio trim that's also got the storage compartment.The one just above the climate control knobs.
On the Evo IX.Because i think the IX and VIII are different.
Old Feb 29, 2012 | 03:30 AM
HaVoC187's Avatar
It just pulls out. Put your hand in the storage compartment and push down on the plastic, you will be able to grab the edge of the trim now and just pull it out
Old Feb 29, 2012 | 03:34 AM
MrJuls's Avatar
Thanks.I guess i have to take out the radio first right?
Old Feb 29, 2012 | 05:22 AM
HaVoC187's Avatar
I pull it out with the radio in it. Just pull it out 1 inch or so, your radio is probably secured in the metal radio "tray". Pry open the clips with a screwdriver and slide the radio out.
Why do you need to be behind it?
Old Feb 29, 2012 | 05:52 AM
MrJuls's Avatar
My boost gauge is located in that storage compartment,and the pipe came off so i have to re-connect the pipe.But i'm thinking i should build the gauge and turbo timer into that storage compartment.Maybe with a sheet of perspex or something.
Old Feb 29, 2012 | 07:53 AM
HaVoC187's Avatar
I took out the storage compartment, then relocated the radio to the bottom hole and closed up the top hole with fibreglass.
I then drilled 3 holes with a hole saw so I can fit my gauges.
I'll see if I can find a pic later.
Old Feb 29, 2012 | 09:32 PM
MrJuls's Avatar
Ok that will be great,thanks.
KeoniGSR9
Feb 1, 2014 02:17 AM
Carrier
Apr 5, 2012 01:24 PM
MrJuls
Mar 9, 2012 01:21 AM
WIREBLADE
Evo X How Tos / Installations
Oct 5, 2010 12:04 PM
Krimsin
Jul 26, 2009 06:00 PM
