Fuelcut decel overrun TPS base
53040010:
Code:
<table name="Fuelcut Decel TPS overrun base" category="Misc" address="5c9c8" type="2D" scaling="uint8"> Code:
<table name="Fuelcut Decel TPS overrun base" category="Misc" address="5c98c" type="2D" scaling="uint8"> I still gotta workout how the TPS is controlled when not in fuelcut.. good luck. |
so, more testing of this, it seems to work as expected..
once your in fuel cut decel increasing this table sets your TPS higher.. I only increased it by 1.5x (which resulted in 16% tps instead of 13%) and my engine braking is muchly reduced, to the point that my speed increases in 3rd on a medium downhill slope.. |
From Tephra
1 lower number = less TPS = more vacuum = more engine braking affect. 2 higher number = more TPS = less vacuum = less engine breaking. |
Is this what Golden has been modifying to help with decel that people have complained about?
My car sometimes has terrible decel or should I say lack there of which I've always thought is more of a safety issue. I am used to standalone engine systems which when setup correctly always have repeatable decel. One thing I've hoped for is a true fix for on stock ecu. Nothing worse then decel not really kicking in coming down a steep grade such as the bridge I cross every day for work and the car actually gaining a little speed. |
So since you have found the decel side, I presume by your comment the next logical side would be the TPS position vs airflow or some variable for resting "idle motor duty"?
you guys mind sharing the addresses for 55570005-6?
Soooo, how does this help us high compression guys? Maybe I will just bug Jon and see what this does for me :)
Originally Posted by black E
(Post 11126390)
<table name="Fuelcut Decel TPS Overrun Base" category="Misc" address="5ca6c" type="2D" scaling="uint8"> <table name="RPM" address="60f4e" type="Y Axis" elements="16" scaling="RPM"/> </table> |
Originally Posted by murlo26
(Post 11127000)
Originally Posted by itzwolf
(Post 11113110)
Originally Posted by JohnBradley
(Post 11129057)
Reduces engine vacuum and engine breaking relative to compression. If you have LOTS of engine braking now it will hold the throttle open to whatever it is set at and help "soften that.
could anyone post up the definitions for a 2010 USDM GSR 55570005? Thank you!
Originally Posted by rrkpitt15
(Post 11130972)
Anyone found this in 5958XXXX (2013)? Unfortunately it wasn't in the new TephraXMod V2 XML for MY2013.
Originally Posted by 99EclipseGSX
(Post 11146282)
58590004: Code:
<table name="Fuelcut Decel TPS overrun base" category="Misc" address="5cc58" type="2D" scaling="uint8"> |
