Help with tune
I've pulled my ROM file from my car, still trying to fix the last owners abuse. I would like some imput on the current tune. I'm having some issues I believe are tune related, idle problems, boost cut, drives a bit jittery at parking lot speeds. If anybody is willing to take a look at my rom image that would be great. PM me or just reply to the post, thanks in advance! {thumbup}
Feel free to post it up, I will take a look when I get a chance.
1 Attachment(s)
Hey thanks for your help! I've attached the hex file.
I wasn't able to open this rom. Do you know what the rom id is?
96531706
Need to add the xml to my rom metadata and I will take a look.
Thanks any help would be appreciated
:eek: nasty
Elaborate please
Finally was able to load your rom. To put it lightly its trash. I'm not familiar with speed density tables as I'm on maf but just looking at your fuel and timing maps whoever made them should be embarrassed. I hope you didn't pay for that tune. It's block tuned and just sloppy. If you are savvy and have tuning capabilities I'd start with a stock map I bet the car would drive better. Please go to a reputable tuner! Do you have a tactrix cable and wideband? Can't really give you advice without knowing your afr and knock sum, but the map just looks rushed and sloppy. My $.02 Can you do some logs and post them up?
Ya figured as much, no so called tune came with the car... I do not have wideband capabilities not money right now for the wideband and downpipe work to install bung. Can I just flash a stock map on for now untill I can get it tuned? Btw I can do
Some logs but without a wideband would it be much help? |
No point playing with the map w/o a wideband. Save up and just get it tuned somewhere. Are you on a stock turbo? What are all your modifications?
Ya stock turbo, mods include... 3 port boost solinoid by hoa, short ram intake, ets intercooler and piping, omni 4 bar map sensor, aluminum pulleys, rc 1000cc injectors, Vishnu exhaust, invida o2 housing, exedy organic clutch.
So I downloaded a stock evo 8 rom and added map table for my omni4 bar and adjusted that, also scaled my injectors and latency to accommodate the rc1000s and considering flashing that on untill I get a tune or would I be better off keeping my ****ty tune untill then?
Flash it... if you don't like it you can put the old tune back on. In the mean time keep saving up for that tune!
