Help with tune
Old Feb 5, 2015 | 09:51 PM
devinfritz's Avatar
Exclamation Help with tune
I've pulled my ROM file from my car, still trying to fix the last owners abuse. I would like some imput on the current tune. I'm having some issues I believe are tune related, idle problems, boost cut, drives a bit jittery at parking lot speeds. If anybody is willing to take a look at my rom image that would be great. PM me or just reply to the post, thanks in advance!
Old Feb 6, 2015 | 04:33 PM
evo8426's Avatar
Feel free to post it up, I will take a look when I get a chance.
Old Feb 6, 2015 | 06:42 PM
devinfritz's Avatar
Hey thanks for your help! I've attached the hex file.
File Type: hex
Old Feb 6, 2015 | 07:16 PM
ronaldo9's Avatar
I wasn't able to open this rom. Do you know what the rom id is?
Old Feb 7, 2015 | 01:36 AM
devinfritz's Avatar
96531706
Old Feb 7, 2015 | 09:24 AM
ronaldo9's Avatar
Need to add the xml to my rom metadata and I will take a look.
Old Feb 9, 2015 | 12:16 PM
devinfritz's Avatar
Thanks any help would be appreciated
Old Feb 9, 2015 | 02:04 PM
todd6027's Avatar
nasty
Old Feb 9, 2015 | 02:36 PM
devinfritz's Avatar
Elaborate please
Old Feb 9, 2015 | 07:23 PM
ronaldo9's Avatar
Finally was able to load your rom. To put it lightly its trash. I'm not familiar with speed density tables as I'm on maf but just looking at your fuel and timing maps whoever made them should be embarrassed. I hope you didn't pay for that tune. It's block tuned and just sloppy. If you are savvy and have tuning capabilities I'd start with a stock map I bet the car would drive better. Please go to a reputable tuner! Do you have a tactrix cable and wideband? Can't really give you advice without knowing your afr and knock sum, but the map just looks rushed and sloppy. My $.02 Can you do some logs and post them up?
Old Feb 9, 2015 | 07:36 PM
devinfritz's Avatar
Ya figured as much, no so called tune came with the car... I do not have wideband capabilities not money right now for the wideband and downpipe work to install bung. Can I just flash a stock map on for now untill I can get it tuned? Btw I can do
Some logs but without a wideband would it be much help?
Old Feb 9, 2015 | 07:59 PM
ronaldo9's Avatar
No point playing with the map w/o a wideband. Save up and just get it tuned somewhere. Are you on a stock turbo? What are all your modifications?
Old Feb 10, 2015 | 08:26 AM
devinfritz's Avatar
Ya stock turbo, mods include... 3 port boost solinoid by hoa, short ram intake, ets intercooler and piping, omni 4 bar map sensor, aluminum pulleys, rc 1000cc injectors, Vishnu exhaust, invida o2 housing, exedy organic clutch.
Old Feb 13, 2015 | 10:20 PM
devinfritz's Avatar
So I downloaded a stock evo 8 rom and added map table for my omni4 bar and adjusted that, also scaled my injectors and latency to accommodate the rc1000s and considering flashing that on untill I get a tune or would I be better off keeping my ****ty tune untill then?
Old Feb 14, 2015 | 11:01 AM
ronaldo9's Avatar
Flash it... if you don't like it you can put the old tune back on. In the mean time keep saving up for that tune!
