problems logging boost and afr in evoscan
hello guys just installed evoscan recently and im knew to using it my car evo 8 has aem uego afr gauge which I think already has white wire connected to pin 75 my problem is when editing the Eval and putting 0.03913*x+9 im not getting accurate afr with my gauge my gauge is at 15 and logged afr is 10 if I increase equation to x+15 afr becomes close but when my gauge drops to 14 my logged jumps to 16
Another problem whit my Omni 4 bar map sensor which is not calibrated in evoscan when I insert the eval and metric eval shown in previous threads around here I get evoscan error RAX_DAT_D MUST preceed boost (map) move RAX_DAT_D TO above boost(Map) anyhelp would be greatly appreciated |
Originally Posted by Evo8life
(Post 11785287)
(Post 11785287)
Have you tried uninstalling Evoscan and re-installing it with 4bar values? Sometimes weird **** just happens in evoscan. Also, through up a log. |
You should just buy a serial port adapter and log afr through it
Are you using the rear o2 sim?
For you map sensor issue, post the formula and a screen shot of your ecuflash data items. Looks like it's expecting some value to be present before the MAP value is computed? I'm not sure |
3 Attachment(s)
Originally Posted by seeaich
(Post 11786141)
I would start off by confirming this.
Originally Posted by 4b11slayer
(Post 11786172)
Originally Posted by butte
(Post 11786273)
Originally Posted by mines5
(Post 11786504)
(Post 11786504)
But still facing issues logging afr equation didnt worked should look to see if connection to pin 75 is already made |
Try Pin 73
(Post 11786172)
https://cimg7.ibsrv.net/gimg/www.evo...c616d8874d.jpg While searching ive found this connector with 2 black and bkue wire is that supposed to be a serial port connection for the afr?its right under the dash |
Yes. That is a serial port. God only knows what those wires are connected to though. You need to trace them back to whatever they are connected to.
(Post 11786803)
https://cimg3.ibsrv.net/gimg/www.evo...bc13b4e113.jpg
https://cimg7.ibsrv.net/gimg/www.evo...c616d8874d.jpg While searching ive found this connector with 2 black and bkue wire is that supposed to be a serial port connection for the afr?its right under the dash Your gonna need to buy a belkin serial to usb converter also |
