Why can't I get mo boost
1 Attachment(s)
Its probably because I'm not understanding something correctly and have something off in one of my boost tables but I can't build anymore boost then spring pressure. I running a 59580304 rom with a Garett GTX3071r gen2 turbo with full exhaust, Omni 4 bar, MAC 3 port ebcs and supporting mods. My (Omni 4 Bar Boost) Boost Target #1A,B,2 is set to 25psi. The (Turbo) Reactive Solenoid Base WGDC Map #1A, B, 2 are set to 99 and (Turbo) Reactive Solenoid Error Correction Interval is 7. No matter what I change or how I change it the boost stays the same. I was using a Tactrix 3 port ebcs with 5/32 hose and changed to the MAC with 7/32 hose. Port 1 (right) goes to the intake tube, between the air filter and turbo. Port 2 (left) goes to the IWG and Port 3 (center). Log from the 3rd gear pull is attached.
https://cimg6.ibsrv.net/gimg/www.evo...f39e6f6ee8.png https://cimg0.ibsrv.net/gimg/www.evo...afc7c5753a.png get pressure from the turbo outlet adapter. |
You have it installed incorrectly.
Port 3 goes to the nipple on the compressor outlet Port 2 goes to Actuator Port 1 goes to intake nipple Also, make sure you have the brown plug connected. |
Thanks for the quick reply... port 3 is going to the compressor outlet adaptor. Poor proofing 🤦♂️
I have it connected to the black ebcs connector though. The Tactrix ebcs w/ pnp harness connects to the black plug. Now i feel like an idiot, never thought to verify the plug. Thanks again for the help |
Originally Posted by nglett
(Post 11936041)
I have it connected to the black ebcs connector though. The Tactrix ebcs w/ pnp harness connects to the black plug. Now i feel like an idiot, never thought to verify the plug. Thanks again for the help Set correction interval to 1 as well. |
It was 100% the plug. Dropped the tables down to 40 on the high end and end up at 53 with a 20# wg spring.
I set the correction internal to 1 as recommended. Does entering a value of 1 offer the fastest or the most amount of wastegate correction and what is the range? |
(Post 11936168)
I set the correction internal to 1 as recommended. Does entering a value of 1 offer the fastest or the most amount of wastegate correction and what is the range? The standard 7 is too slow once you start making decent power. |
| All times are GMT -7. The time now is 07:36 AM. |
