How many times have you flashed?
Old Nov 26, 2006 | 05:27 PM
cecilseahawks's Avatar
I'm on 20 in the first two weeks of using ecuflash. Just curious how many times have been done without any issues.
Old Nov 26, 2006 | 05:37 PM
cij911's Avatar
I am probably on ~50
Old Nov 26, 2006 | 05:46 PM
cmz's Avatar
cmz
I've been tempted to start a thread on this a few times.
Supposedly there is a limit to how many times you can flash an area of memory. Ecuflash only reflashes the data that has been changed, not the whole memory space. This makes it more unlikely that you'll burn out any one memory address....
But, what is the limit?
I've not seen any number backed up by research or practical experience, yet.
And how would too many writes manifest itself? Does Ecuflash verify it's writes?
Another thought, if someone did run into this, is it possible to replace the flash memory (or upgrade it so it wouldn't be an issue again?), or are we stuck trying to source a compatible ECU?
Old Nov 26, 2006 | 06:36 PM
RazorLab's Avatar
over 100 in my personal car.
Old Nov 26, 2006 | 06:42 PM
jmoudry's Avatar
At least 40
Old Nov 26, 2006 | 06:54 PM
cpoevo's Avatar
About 25 here. Some tuners have said the limit is around 1000.
Old Nov 26, 2006 | 07:20 PM
AlwaysinBoost's Avatar
me 2
Old Nov 26, 2006 | 10:54 PM
chrisw's Avatar
I forget how many... over 60 times at least.
Old Nov 26, 2006 | 11:10 PM
wirespeed's Avatar
i have around 20...what i really want to know is how many someone has flashed it before it burnt or if someone flashed it over 1000 (some say that is the limit) and is still runnig.
Old Nov 27, 2006 | 05:51 AM
C6C6CH3vo's Avatar
Three different purchaced ROMs, and 35 personally made ROMs (38 total) have been edited to my ECU.
Healthy electrical and ignition system, and carefull flashing practices are required for 1000 more - I hope
Old Nov 27, 2006 | 12:03 PM
3gturbo's Avatar
150 on my eclipse ecu and 40 on the evo ecu
Old Nov 28, 2006 | 06:19 AM
MalibuJack's Avatar
I've probably flashed my personal car 2 dozen times or so..
I think the company that makes the flash chip certified the chip for 100 fault-free writes.. its obviously quite higher than that.
I wouldn't worry too much about it. But just so you know, the way ECUFlash works, is it only writes areas of the rom which has changed.. so if you reflash your ECU once for injector scaling, then another time for your boost control, then another time for your fuel map, each of those reflashes only overwrites changed bytes in those specific areas.
Errors begin to happen when you overwrite the same location, for instance if you changed the injector scaling byte hundreds to thousands of times, then you may get write errors for the specific byte. Obviously its a bad thing, but its unlikely to cause you a problem unless your reflashing your car so often (for instance overwriting your timing map repeatedly for along period of time, hundreds of times)
I keep a working backup ECU around just in case (it also has my stock flash on it) but its only because I want to be safe, and I always keep backup components in my shop.
Old Nov 28, 2006 | 06:22 AM
MalibuJack's Avatar
FWIW there will be a point in the near future where we will be able to alter values in the ECU ram through software, which means tuning the car and updating values, without reflashing the ECU until you have a map that is complete..
It looks like this is very close, and requires only minimal mods to do it (and of course software capable of doing it) this has been discussed on my site during the disassembly of the rom, and one of the main contributors had mentioned a method of reading/writing the ram area using a modified mut request..
Old Nov 28, 2006 | 03:24 PM
MRadjahoe's Avatar
1,000+
Old Nov 28, 2006 | 05:23 PM
cmz's Avatar
cmz
Jack - As in modify data in RAM such that it is retained even when the car is turned off and doesn't reset unless the battery is disconnected?
