ECUFlash / Evoscan / Mitsulogger Questions
#826
couple of questions regarding EvoScan
1. my AFR log show 10 across the board, i know that is not right. I m on E85
2. my boost log shows 48psi I know thats not correct.
3. can i find out my boost with looking at Loadmut? my max Loadmut was 403
thanks
thanks
#830
I have a question, now that I am running speed density I threw a check engine light on the way home from the dsm/evo shootout and now my evoscan wont let me check it. I haven't read through all the pages, but it says:
"arithmetic operation resulted in an overflow"
Can anyone help me on this one. I have tried to load and reload evo scan and to no eval its not working for this any idea's?
#834
EDIT:
No the new software did not help. It still says "Arithmetic operaion resulted in an overflow." Now it says this in the troble cods section and the clear dtc does not clear this code so Idk wtf to do now anyone have any ideas where I should or who I should talk to? And sorry AND I missed answering your question. I am currently using a 1.3 tactrix cable and new 2.7 evoscan software.
#835
I recently got an openport 2.0 (with the Mitsu flash cable) and upgraded to Evoscan 2.7 and the beta ECUflash all at the same time. I can log just fine (except it no longer reads DTC codes), but nothing I do seems to allow ECUflash, either the beta version or the previous version, to connect to the ECU. The buttons aren't even highlighted. It's as if the cable isn't connected. I'm trying to tune a friends car and convert it to SD. It's been 2 days of messing with everything and still no luck. Any ideas? I've uninstalled ECUflash and cleaned out the registry to remove all traces and still no luck. I'm getting frustrated.
#836
Nevermind I finally figured it out. The beta version of ECUflash uses a new 2.0 driver that isn't backwards compatible with older versions. Since the beta just crashed whenever I opened a V7 ROM I gave up on it and went back to 1.42. For future reference if this happens to anyone go into windows "add or remove programs" and delete all the openport drivers then reinstall ECUflash 1.42 until the newest beta is more stable. The newest driver won't work at all. I also got EVOscan 2.7 to read DTC codes again when I went back to the older 2.0 driver.
