ECUFlash / Evoscan / Mitsulogger Questions
Old Jun 1, 2014, 11:06 AM
  #1516
RST_89's Avatar
Originally Posted by evoscan
open the hex file with ultraedit or notepad++ and go to the rom id hex location and you can see what the RomID is, you can download the definition from the Mitsubishi database in my signature below.
This description (above) doesnt work for me because when i open the *.hex file with notepad i see strange signs wich are not working.
When i open a *.xml file everthing is ok.
Did i do something wrong?
my evo was mapped once. i have no problems with my engine but i want to change a few little things in my fuel map.
would you be so kind and help me. thanks in advance
File Type: hex
Old Jun 3, 2014, 01:16 AM
  #1517
Silver Sponsor
evoscan's Avatar
no I didn't say notepad... I said notepad++ very different things. or use ultraedit, thats what I use. and press ctrl+H to go to HEx mode, and click ctrl+G to go to the position 0xF52 and press enter. here you will see your ROM number like 8digits, like 24430002. There was a tuning guide floating around somewhere with this in.. I think it is on my www.evoscan.com website under tuning guides.
if you go to
C:\Program Files (x86)\OpenECU\EcuFlash\rommetadata\mitsubishi\evo\
and open some sample xml files you will see this, this is what ecuflash is matching it to. it actually scans ALL of your xml files looking for a match against your rom/hex file.
<internalidaddress>f52</internalidaddress>
Old Jun 3, 2014, 12:02 PM
  #1518
RST_89's Avatar
if you go to
Sorry but i used the notepad++. now i use the ultraedit! opened the file what i downloaded from my ecu (read from ecu) with evoscan. Searched the 0xF52 in the HEx mode. i think this is the Rom ID 96530006 ??
Please look at my screenshot.
What should i do with this number? i tried to put this Rom ID in the input file download with the evoscan software (Optional ECU Init unlocker code in Hex (i.e. F0F0): 96530006
without succes can not open the file with EcuFlash after downloading with evoscan?
Attached Thumbnails ECUFlash / Evoscan / Mitsulogger Questions-ultraedit-rom-number.jpg
Old Jun 3, 2014, 04:08 PM
  #1519
jungle's Avatar
send me an email with your map file and xml file, and if I get the same error, I can send you an updated version with a fix.
Thanks, Pm sent for your email address.
I've reloaded previous versions of Evoscan, they all give the same error.
Cheers
Old Jun 4, 2014, 06:56 AM
  #1520
Silver Sponsor
evoscan's Avatar
@rst89 yeah there is a rom called 96530006 - good work. you passed tuning 101 class
next... download 96530006 from this page http://www.evoscan.com/roms/mitsubishi/
and save it in C:\Program Files (x86)\OpenECU\EcuFlash\rommetadata\mitsubishi\evo\
then open ecuflash, and open your hex using ecuflash.
Old Jun 4, 2014, 06:58 AM
  #1521
Silver Sponsor
evoscan's Avatar
Cheers
oh, legnum.. this sounds dodgy already yeah send it to my email address support at evoscan dot com and I'll load it in my evoscan and ecuflash to see the issue.
Old Jun 5, 2014, 02:56 AM
  #1522
jungle's Avatar
Dodgy im not sure the guys that did the defs would agree.
Thanks for taking a look. Happy for any help.
Cheers
Old Jun 5, 2014, 11:32 AM
  #1523
RST_89's Avatar
lol
I m proud of myself
i downloaded the 96530006.xml file from the evoscan page and saved it in C:\Program Files (x86)\OpenECU\EcuFlash\rommetadata\mitsubishi\evo\
then i opened the downloaded file with evoscan (FlashImage_20140306_2006.hex)
Unknow ROM image ???
thank you
Attached Thumbnails ECUFlash / Evoscan / Mitsulogger Questions-unknow-rom-image.jpg
Old Jun 5, 2014, 04:03 PM
  #1524
Silver Sponsor
evoscan's Avatar
you forgot to email me your VR4Base.xml file
inside EMKS11.xml I see this: <include>VR4Base</include>
Old Jun 5, 2014, 04:08 PM
  #1525
Silver Sponsor
evoscan's Avatar
yeah check for any <include> then download those xml and put them in the same folder
Old Jun 6, 2014, 02:38 AM
  #1526
jungle's Avatar
Ah i didn't realise it wasn't there… sent to your support email
Cheers
Old Jun 6, 2014, 03:24 AM
  #1527
jungle's Avatar
So i need the base xml file in the same folder as the updated xml file? Is that what's stopping EVOscan from showing the map for the map trace function?
Old Jun 6, 2014, 08:32 AM
  #1528
RST_89's Avatar
sorry but i dont understand what you mean with the symbol <include> ?
Old Jun 6, 2014, 12:33 PM
  #1529
PhantomBlackEVOX's Avatar
Completely new to the data logging/ECUflash community...I have a galaxy tablet and was wondering if ECUflash has an app to run on it instead of a laptop? I know EvoScan has the android tablet but not looking to buy another tabled just for data logging. thanks guys!
Old Jun 7, 2014, 04:22 AM
  #1530
Silver Sponsor
evoscan's Avatar
I opened your rom, and I saw MKS11 written inside your rom at address 1fefa
so you should edit your MKS11.xml and change this to 1fefa instead.
<internalidaddress>2fefa</internalidaddress>
Quick Reply: ECUFlash / Evoscan / Mitsulogger Questions
