Official 2 byte thread!
#151
That's what I did, it seems the 013 and 015 are very similar. Everything seemed to work fine, although the values in EVOscan were very strange.
Do I have to change the function in evoscan?
My current functions are
0.3125*x Load
3.906*x RPM
6.29*x/64 AIRFLOW
I know on the first page it states to change RPM to 1000*x/256 but my values are still very strange. Did I do something wrong?
0.3125*x Load
3.906*x RPM
6.29*x/64 AIRFLOW
Anyone else able to verify the new (differnet) functions are correct with EV2.2 ?
#152
0.3125*x Load
3.906*x RPM
6.29*x/64 AIRFLOW
0.3125*x Load
3.906*x RPM
6.29*x/64 AIRFLOW
#154
Yeah you did that perfectly. If you are getting false readings, the 013 ROM must have different addresses than the 015 ROM uses. You'll have to nag one of the ROM Disassembly guru's on here to help find the correct address' for you. If you do find out, post up the correct address' on here and I'll update them for anyone else in the future.
#155
Thanks for your help
#159
014 Rom
Hmm, does anyone know if the 014 (88590014 ROM) uses the same MUT table start address location and 2 byte load values as the 013??? I've got the 014 and want to start logging the 2 byte load, trying to determine the right MUT/2 byte addresses before I make the .xml mods to the def file.
Thanks in advance,
Mitch
Thanks in advance,
Mitch
#161
How?
Tephra,
I'm only about 1 week into ECUFlash, so I'm not completely sure how I "upgrade" to the 015 ROM.
Is it as simple as:
1. Getting a copy of a stock 015 ROM
2. Updating the stock 015 ROM file with the 2 simple changes I've made to my 014 ROM
3. Flashing the updated 015 ROM into my ECU????
Any downsides to migrating from the 014 to the 015??
Anyone have a stock 015 ROM they can send me???
Thanks in advance,
Mitch
Is it as simple as:
Thanks in advance,
Mitch
#164
All I've done on my 014 ROM is bump the idle timing from 5* to 7* (all 6 tables) and put in hybrid MIVEC map...should only take me a few minutes to cut and paste onto on 015 ROM.
Just have to remember to change the immobilizer code too before I flash it!
#165
Call me lame but i can't get the mut table to show up. I copied the xml data in and put in the address for my rom evo9 15 and i get an error right on the first line of code when i launch ecuflash. It references a column aside from the row that isn't even there. anyone have a working 15 xml for me to test? pm me with addy or i will pm back mine thanks. this is frustrating.
does the downloaded text file with XML data need any editing aside from the address for your particular rom?
Does it matter if you have 1D for RPM already defined?
this is something simple i know it
I tried on different computers and everything
