Ingersoll Rand Boost Solenoid, confirmed works and cheap
Old Sep 22, 2008 | 08:27 PM
mchuang's Avatar
I decided to test the Ingersoll Rand 3 Port Boost Solenoid which is pretty much identical to the Perrin, but 1/3 the price.
Bought it here http://www.drillspot.com/products/41...Solenoid_Valve
it was 27.00 plus shipping came out to 33.00. There is another site that sells it for 23.00.
The good thing is that it is industrial grade and made out of aluminum so it looks pretty stout from appearance. Another good thing is that you do not have to wire a resistor up because as it sits it is about 37ohms, the gm is 29 ohms and 40 ohms with the resistor and the stock solenoid is about 33-34ohms.
Only thing you have to buy are the 1/8th npt barb fittings with 1/8th outlets from the local hardware store. You will need 3 of them and teflon tape. All this came out to about 7 bucks.
Parts list
Ingersol Rand Solenoid - 33.00 shipped
No Pigtail, wires a preconnected in the solenoid
Resistor - 0.00
3 - 1/8th npt barb fittings 1.29 each
teflon tape - 2.00
I use to have the GM solenoid hooked up and once I hooked up the Ingersoll Rand Solenoid, I had to turn down the WGDC because I started to overboost right away. As far as mounting, I unscrewed the stock solenoid from the bracket and mounted the new solenoid in its place. So far 2 days and it works just fine. Unfortunately I do not have any before and after boost plots since I dont have a 3 bar connected. Havent been playing with the car much, new born on the way in 8 weeks!!!! So I gotta save only can play with cheap lil toys like this hahaa. Anyways here are pics for those interested.
Old Sep 22, 2008 | 09:19 PM
mrfred's Avatar
I've read that the GM solenoids are pretty loud. What about the Ingersoll-Rand?
Old Sep 22, 2008 | 09:25 PM
mchuang's Avatar
Not loud at all compared to the GM, you can hear it though
Old Sep 22, 2008 | 09:34 PM
lapulapu's Avatar
How are you routing the vacuum lines to the solenoid? Is it like this?
Attached Thumbnails Ingersoll Rand Boost Solenoid, confirmed works and cheap-vaccumlines.jpg
Old Sep 22, 2008 | 10:00 PM
tephra's Avatar
i can't hear my GM... at all.
weird your WGDC changed??!?
Old Sep 23, 2008 | 04:10 AM
mchuang's Avatar
Yea I am routing exactly like that. Which according to the diagram is interrupt.
Old Sep 23, 2008 | 04:12 AM
mchuang's Avatar
It didn't change, I had to lower it after adding this solenoid. Not much maybe about 15% overall. Should it have been the same as the GM. If so the only thing I can think of is that on the GM when you add the resistor, voltage supply is slightly reduced as far as I know, could be wrong though.
Old Sep 23, 2008 | 06:49 AM
lilnaz's Avatar
It is a good solenoid I use it to. It works really well controlling boost. You can get it at mcmaster.com for the same price. Its the same unit used in the Perrin ebcs kit. No resistor needed just splice and solder it in.
Old Sep 23, 2008 | 08:19 AM
lapulapu's Avatar
from your pictures you might have it routed incorrectly. According to Perrin's diagram, you are to use Port 1 & 3 but it looks like you're using 1 & 2.
Old Sep 23, 2008 | 08:44 AM
MR Turco's Avatar
I also do not hear my GM. I am shocked anyone that drives an evo would complain the BCS makes noise. Am I the only one driving the car with the nosiest drivetrain on the planet?
This is good info though. Maybe the cheaper price will help persuade some of the local guys to finally move to ECU controlled boost.
Old Sep 23, 2008 | 08:58 AM
honki24's Avatar
Congrats on the child! Man do I know what that's like. I'm in the same place as you. I can only afford to fix/do the small stuff right now. Just had twins 5 months ago.
Good find. Way to be experimental.
Old Sep 23, 2008 | 10:26 AM
RazorLab's Avatar
Hehe, a local shop sold those as their "ECU boost solution" for much more than that price.
I always wondered what solenoids they where, I never looked into since we/I use the GM's.
Interesting thing was the shop set them up so less WGDC makes more boost. I guess they wanted to be different.
Old Sep 23, 2008 | 04:34 PM
mchuang's Avatar
I am not sure, it seems to be boosting fine. Also the perrin diagram seems to label ports differently from the ingersoll rand one. I think you are looking at the one port at the top of the 2 and that one normally routes to the intake but i have it just shooting down not connected.
Old Sep 23, 2008 | 06:42 PM
EatSleepBoost's Avatar
i am confused about these sensors. i know people change the map sensors to control and log boost i believe. Does this replace the stock wgdc solenoid?? or is it in addition. what are the benifits to going with a set-up like this? Sorry, i am very confused but a reply or a pm with any information would be greatly apreciated.
Old Sep 23, 2008 | 07:06 PM
mrfred's Avatar
These aftermarket solenoids can bleed off more pressure from the WG, so they allow a wider range of boost control. Some say that these solenoids are faster as well which would give more precise boost control.
