Timing & Fuel maps: Load auto-rescaling (XLS file)
Old Nov 16, 2008 | 10:02 AM
Vigman's Avatar
Post EASY WAY TO RESCALE Timing & Fuel maps (XLS file)
Hi everybody,
Here is an Excel file I did to automatically rescale load axis on timing and fuel maps.
You can use your own value to set max load or paste your "logged load" to get it fully automated...
I tried to make it easy to use and I feel it's like "close to be ok" but I know your opinion will be constructive.
Tell me if you think it is useful and post your feed to let this file ready for the community...
The first sheet is the "how to", so start from here....
Cheers,
Christian.
Old Nov 18, 2008 | 10:19 AM
Vigman's Avatar
Hi guys!
I have seen on my server log files that at least 35 of you have downloaded the XLS file....
Since it is a "beta" version, I really would like to get some feedback so don't be selfish and post your comments in order to make it better if necessary!!!
Thank you for your time.
C>
Old Nov 18, 2008 | 04:52 PM
evo082006's Avatar
Really like the rescale tool, would you be willing to make one for the EVO 8 ECU, my ECU doesn't have as many lines as a 9.
Old Nov 18, 2008 | 06:29 PM
Vigman's Avatar
need 8 rom...
Let me see if I can get an VIII rom to modify the file...
Old Nov 18, 2008 | 07:58 PM
oldevodude's Avatar
I am one of the 35 who downloaded it but have not checked it out yet
Old Nov 23, 2008 | 05:46 PM
evo082006's Avatar
emailed you an 8 rom
Old Nov 23, 2008 | 05:55 PM
joedr's Avatar
EvoM Moderator
Works very good indeed!
Quick question....
What is the use for this portion?
Events LoggedLoad (WOT) full loads sorted Steps between
Thanks for sharing!
Old Nov 23, 2008 | 11:00 PM
acamus's Avatar
From: Lattitude 48.38°, Longitude 17.58°, Altitude 146m = Slovakia, for common dude
Originally Posted by Vigman
Hi everybody,
Cheers,
Christian.
Nice work Vigman, maybe it is about the time to add scripting support to ECUFlash.
Anybody in hold of Colby's mail to suggest him a change?
Old Nov 24, 2008 | 04:13 PM
Vigman's Avatar
Quick question....
Thanks for sharing!
I put this column to paste your wideband capture (D18 - D114) then AFR are sorted (E column) in order to evaluate the "suggested" max load value (E2).
The "step between" part is to have a look just is case you want to reduce the load gap in a precise region..
Old Nov 26, 2008 | 01:33 PM
Vigman's Avatar
Here is a version for VIII rom.
Thanx to evo082006 for the tables.
I hope it could help.
To all of you who used this XLS, please send your feedback to make adjustments if necessary!
Cheers.
Old Apr 1, 2009 | 05:08 PM
fostytou's Avatar
EvoM Community Team
I wanted to bump this and say thanks a ton for the App, it made things much easier.
I wanted the same "linear" headings that the Stock ECU has, so I input my own values for the headings on page 2. The interesting thing was that it changed all of my fuel values slightly (timing was fine) when I really only had to "shift" everything 2 rows. I'm sure this is just because it is calculating that shift rather than doing it, but as a heads up for anyone who wants to be sure things are the same, you may want to just "shift" any chunks that are not changing yourself.
Thanks again!
Old Apr 1, 2009 | 07:54 PM
PeteyTurbo's Avatar
Does this change/move your actual values in the map as well or just give you a load axis??
Old Apr 2, 2009 | 01:56 PM
fostytou's Avatar
EvoM Community Team
It will create (or allow you to define) new load axes and then automatically "scale" or shift all of the values in the table for you. It works incredibly well.
Old Apr 2, 2009 | 02:44 PM
sti.this's Avatar
nice. Im going to check this out. will report back.
Old Apr 3, 2009 | 12:57 AM
PeteyTurbo's Avatar
Sweet, I just tried it and it works great.. Of course I went through it with a fine tooth comb but everything looks perfect..
