Openport 2.0 unusable
It works with EVO 4-9, I have a EVO9 ECU here on bench that I am testing with.
New Mut Monitor Version 1.8 released today
http://www.myrollingroad.com/showthread.php?t=103
Cheers
sean.
Cheers
sean.
Cheers
sean.
Cheers
sean.
First, thanks for the work you've been putting in for the Evo community; it hasn't gone unnoticed.
And do you have plans to get MUT Monitor working on the Evo X? If there's anything you need from us X guys, just let us know.
Thanks again.
ECUflash now updates the Firmware on the OP2.0 cables and seems that the Reply packets for MUT and OBD-II logging no longer come back.
At the moment PCMscan (uses OBD-II ) has stopped working with the OP2.0 cable this end and Mut-Monitor.
So now have to wait for a new Firmware update to come along.
Have started to look into the Canbus Protocol that the X uses, so hopefully in the future
My PCMScan is working now, mine just seemed to be a problem with the driver installation. After I read Manboy's post, I uninstalled/reinstalled everything and it works fine now.
