Octane Level
Octane Level
I live in Dominica in the West Indies and our fuel is claimed to be 95ron. I have a alchohol kit and I am running a 50/50 mixture of water to meth.
Should i be able to run more than 23 psi?
FP EVOGreen site says
This turbocharger operates very well in the 20-22psi range on pump gas, and 24-28psi on E85 and 26-32psi on C16.
Engine/Performance Modification
FP Evolution Green Turbocharger - Turbine Housing 10.5cm
Delphi - 750 cc Injectors (75lb )
ARP - Head Studs 11mm 2G
Wiseco - Pistons - Compression Ratio 9.1
Eagle - H Beam Connecting Rods[/u]
Cams - GSC Exhaust 272 duration 10.2
Cams - GSC Intake 272 duration 10.8
AEM Perfromance Air intake System
Front Mount Intercooler - Greddy Trust
Aluminum Intercooler Pipes
Header Manifold
O2 Housing - O Tomei EVO Expreme
Down Pipe 3’- O Tomei
Test pipe 3" - Mc Millan
Full Exhaust 3'- Greddy Trust
Catback Exhaust - GReddy Titanium Exhaust
Clutch - ACT HDSS 475 bhp
Clutch Line - Steel Braided
Boost Controller - Greedy Profec B-Spec II
Re-flashed ECU 23 ps
Fuel Pump 255lph - Walbro
Blow off Valve Greedy Type S
Oil Catch Can
Alchohol Injection Kit - running 50/50 Meth/Water
Header Manifold
Oil Catch Can
You'll find that a wide variety of boost pressures is possible on a wide variety of fuels. Some people run 30psi on 91 octane and others run 20psi on 93 octane. It all depends on the tune.
In your case, you can probably safely tune to 28-30psi, thanks to your meth injection, although you do have 9:1 compression so results may vary. You may want to go to a higher percentage of methanol to get the most out of your setup. Personally, I use 93 octane + 75% meth on the stock motor, boosting 30psi.
