NLTS(No Lift To Shift) For Beginners
Old Sep 1, 2009 | 11:51 AM
scheides's Avatar
EvoM Moderator
First off, you need tephra mods installed on your ecu to do this. I hear lots of people having lots of trouble or are so scared to try NLTS on their car ever. I have used it for the last two years literally all the time with no issues as a result. Don't be afraid, just practice.
Why does everyone insist on testing NLTS while WOT@7000rpm?
If it's your first time, do yourself a favor and put the car in third gear at 3000rpms. Go WOT and then push the clutch to the floor AND HOLD IT THERE. If the engine free revs, let off the gas instantly. If it drops down and bounces off of the rev limiter at 2200rpm (or whatever) then you're golden. Let off the gas, then gently let out the clutch and continue driving.
Try it again at 4500 a few times, do not dump the clutch out yet. Get a feeling for holding the clutch and gas pedal to the floor at the same time; you need to unlock the seesaw in your mind between these two pedals, its been there for however many years and its not going away easily
Now go WOT @ 3000rpm in third gear and try a slow NLTS at 4500rpms or so. Gas pedal is pinned to the floor, clutch to the floor, verify motor is not free revving to the moon as you shift to fourth, then quickly but gently let out the clutch and keep your right foot pinned WOT. You should be about 3500rpm in 4th gear and accelerating hard. Let off the gas, giggle, and then do it again at a higher rpm.
Normal Problems:
1--During non-NLTS shifts, the car cuts out when you get back at WOT after a shift. Remove your left foot from the clutch pedal, you're riding it a bit.
2--I had a friend who just could not get over the seesaw thing and could not keep the gas at WOT while doing a shift, even at low RPM for practice (as described above). This was my car he was driving, I had verified NLTS was working properly, so I simply reached over just as he went WOT and pushed down as hard as I could on his knee so he would not let off the gas. That was his first successful test (as above) and a few tries late he was ripping WOT NLTS @7000rpm.
3--Same friend as above, but he had bought his own precious WW Evo IX and had not quite gotten the hang of it at high rpm. The shifts were a little stumbly and he was not wanting to have this abuse on his beautiful new car. I encouraged him to try it 'one more time' on an onramp, no traffic, and he finally got the shifts down smooth. YES I said SMOOTH! NLTS shifts should be smooth, not violent. He then told me that I had better not turn off NLTS on his rom or he would be pissed!
4--I had a friend that does a lot of autoX. He kept hitting the NLTS rev limiter as described in issue #1 above while doing autoX, so we raised the minimum speed from 30kph up to roughly the top of 2nd gear so his 1-2 shift would never be NLTS. Also tried higher so only could do NLTS 3-4 and 4-5.
Old Sep 1, 2009 | 11:56 AM
Kracka's Avatar
NLTS rocks
This thread is for you, Kai!
Import Junky's Avatar
Do you need the connector hooked up for the clutch pedal? I removed it so I could start the car in the winter months without having to hop in and press down the clutch.
Old Sep 1, 2009 | 11:58 AM
Mellon Racing's Avatar
this mod doesn't compare to real NLTS
Old Sep 1, 2009 | 12:00 PM
I don't get it? Chris could you elaborate? What's real NLTS? Just slamming gears with both pedals depressed as fast as you can?
Kracka's Avatar
No. The switch disconnected for no-clutch starting is not the same one used for NLTS. Scheides and I both have our lower switches disconnected for no-clutch starting.
Old Sep 1, 2009 | 12:01 PM
Kracka's Avatar
Correct
Old Sep 1, 2009 | 12:03 PM
scheides's Avatar
EvoM Moderator
No, the lower connector does not need to be hooked up, I have mine unhooked and still NLTS just fine. Tephra's NLTS patch is based on the upper switch (thus the 'riding the clutch' issues)
True, but I think its much better/smoother for the average DD car not looking to blow xfer cases and just have fun ripping it up on the street. Try this patch while doing a more basic quick shift (i.e. not a power shift), you'll be shocked at how smooth it is.
I think what you are talking about is referred to as 'power shifting' right?
Evostacio's Avatar
is this the same as keeping your foot on the peddle and just shifting...
Old Sep 1, 2009 | 12:25 PM
this mod cuts power when the clutch is engaged whereas real ntls aka powershifting does not so you gain rpm and don't lose boost
Old Sep 1, 2009 | 12:31 PM
Kracka's Avatar
Tephra NLTS seems to consistently hold 10 lbs/boost on my car between gears.
Old Sep 1, 2009 | 12:32 PM
scheides's Avatar
EvoM Moderator
this mod cuts power when the clutch is engaged whereas real ntls aka powershifting does not so you gain rpm and don't lose AS MUCH boost
FTFY Doing NLTS w/ tephra's mods you can hold 15psi pretty easy inbetween gears and keep the turbo spinning nicely!
How much do you hold on a powershift?
Old Sep 1, 2009 | 12:34 PM
I don't lose any, the rpm's rise when I shift
Old Sep 1, 2009 | 12:39 PM
EnjoyDriving's Avatar
Originally Posted by S2kracka
NLTS rocks
Here I am!! hahaha...
Old Sep 1, 2009 | 12:41 PM
Jack_of_Trades's Avatar
Old School NLTS'ing is sweet but not for the average Joe. Tephra's is a good compromise between Old School NLTS and full lift to shifiting.
