FIX: 96530006 V7 tephra stationary rev limit does not work
Old Jul 28, 2011 | 09:57 PM
dparrish's Avatar
Do exactly what it says, replace all with 0x0009 except for the last one, put 0x3ab6 in there.
I don't know anything about the eastern creek time attack. If you PM me details or a thread where there are details, I'd like to!
Old Jul 28, 2011 | 10:07 PM
ziad's Avatar
change all except the last one.... so change the first one to 0009. thanks
Old Nov 6, 2011 | 06:25 AM
EvoIIIAj's Avatar
Can't someone just post the edited XML for the inexperienced?
Old Nov 8, 2011 | 08:47 PM
ziad's Avatar
dude as my prev post says change all cells in the table to 0x0009 except the last one. the values in the xml are there incase u want to revert back to what was originally in ur rom... incase u wanted to reverse this patch.
Old Jul 19, 2013 | 12:54 PM
marcouxa1's Avatar
Will this work on an evo 9 rom? im using the 88590715 rom in my turbo lancer oz and my stationary rev is not working either
Old Jul 19, 2013 | 01:57 PM
211Ratsbud's Avatar
I think that's a different issue. Do you have two clutch switches?
Old Jul 21, 2013 | 03:50 PM
marcouxa1's Avatar
Im pretty sure i don't...although the evo 8 launch control works on 02-03 lancers...but the evo 9 doesn't seem to work on my 06 lancer...and i can't flash a evo 8 rom because they're 250kb roms (sk7052) and mine requires a 550kb rom (sk7055) to flash it into a oz ecu....im wondering if the evo8 and 9 use a different method to activate the launch maps/rev limiter?
Old Aug 3, 2014 | 11:56 AM
andyvi's Avatar
old thread i know but a big thanks to the OP worked a treat for me using v7 on a 7 ecu
Old Oct 31, 2015 | 01:42 AM
mines5's Avatar
I am facing this weird issue. I am using the 9653 v7 rom patched for v7. e7 gta ecu in evo 4.
When i flashed it first the stat rev was working fine. Since i changed the injectors and made launch ignition and fuel maps. The car started building up boost but stat rev doesnt work now. Even with ziads patch on. Max timing retard logged was -10.
Any help is appreciated.
Attached Thumbnails FIX: 96530006 V7 tephra stationary rev limit does not work-stat-rev.jpg   FIX: 96530006 V7 tephra stationary rev limit does not work-launch-map-ign.jpg
Old Nov 1, 2015 | 01:32 AM
mines5's Avatar
bump .....any one?
Old Mar 1, 2016 | 04:23 AM
dr_jing's Avatar
any one can post up the xml code for this?
Old Mar 1, 2016 | 09:28 AM
todd6027's Avatar
click on quote below the first post it comes up in the reply
Old Mar 2, 2016 | 02:26 AM
dr_jing's Avatar
Thanks man
recompile
Mar 3, 2024 05:00 PM
mrfred
Jan 6, 2024 09:43 PM
mrfred
Sep 14, 2022 07:08 PM
SsZERO
Mar 15, 2019 01:40 PM
Poondoggs
Jun 6, 2016 08:33 PM
