Log AEM UEGO in evoscan using analog output?
Old Feb 9, 2010 | 08:48 AM
DBallz's Avatar
From: South Beach, FL / Miami, FL / Pt. St. Lucie, FL / NYC
So I have done some searches and I haven't really found a "How To" yet. I'm wondering if it would be similar to MrFred's "How To" on the Innovate LC-1?
Any ideas?
Old Feb 9, 2010 | 09:22 AM
travman's Avatar
Any ideas?
yes - its the same process, different calculation in evoscan.....many have already done it, if you search that LC-1 thread you will probably find AEM info.
Old Feb 9, 2010 | 09:55 AM
03lances's Avatar
Originally Posted by fostytou
FYI for anyone with an AEM wideband here is the equation and a chart:
http://thefrost.net/randomfiles/tuni...F+R_O2_Sim.xls
Base equation is 0.039137255*V+10
Code:
mL	        1/mL	         bL/mL
0.039137255	25.5511022	255.511022
Here you go
Old Jun 8, 2010 | 02:39 AM
VGergo's Avatar
Hello
Which one formula shoud use in the Evoscsan to log AEM UEGO AFR with the analog output ? This one posted here : Base equation is 0.039137255*V+10
but in other topisc I saw 2 more : 0.03913*x+10 and 0.03137*x+10.0
Which is the most accurate ?! Thanks !
Old Jun 8, 2010 | 11:55 PM
VGergo's Avatar
I need to copy that text in the evoscan data.xml with right formula for AEM Uego to able to log by evoscan ?
<DataListItem DataLog="Y" Color="" Display="Wideband AFR" LogReference="WideBand" RequestID="12" Eval="0.05859*x+7.35" Unit="AFR" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="22" ChartMin="0" ChartMax="22" ScalingFactor="1" Notes="" Priority="1" Visible="false" />
and set MUT12 to 8409 ?
I will wire in today my uego and will try it just would be better if i know which formula is working well ?!
Old Jun 9, 2010 | 02:07 PM
keith sedlak's Avatar
darkmitsu posted "how to log your aem EUGO with evoscan" i am going to try to set it up that way tonight. dont know if that spelling is right but thats how he has it?
Old Jun 9, 2010 | 03:01 PM
bvasquez12's Avatar
https://www.evolutionm.net/forums/la...o-evoscan.html
Old Jun 9, 2010 | 07:01 PM
VGergo's Avatar
oh yeas thanks a lot it is nice write up. i will set it. If i disable the rear o2 heat cel than I can completly remove the stock rear o2 ?
Old Jun 16, 2010 | 06:12 AM
VGergo's Avatar
I did evertyhing how bvasquez12 link said in the #7 post but I have to use the formula in evoscan : 0,03913*x+10 to get exactly the same value in log as the gauge show Cool it is working.
Old Jun 16, 2010 | 09:29 AM
diiirk@AwdMotorsports's Avatar
Set it up just like the innovate. Works the same, just need a different formula.
BTW, i also have this working the same way using an aem oil pressure gauge. If anyone is interested in the formula let me know.
Old Jun 9, 2012 | 05:55 AM
DBallz's Avatar
I know I'm bringing this post back to life but I tried it the other day and when the car was running basically in the 14.7 gauge range evoscan was showing me in the 10's I literally applied the instructions as per Darkmitsu posts and it's just way off.
Old Jun 9, 2012 | 05:57 PM
DBallz's Avatar
Anybody want t help? At 1st I thought I was using the wrong wire but now I'm still not sure. PLS HELP
Old Jun 15, 2012 | 09:09 AM
EnjoyDriving's Avatar
have this been solved yet? I'm about to do the same to my IX, and as I'm reading from the link above, he only talked about wiring up the "WHITE" from the gauge to pin75 on VIII, which I believe will be pin73 on IX, am i right? But, he didn't say anything about the "BLUE" (the ground wire), do we just leave it alone or we need to have it grounded "bolted to somewhere on chasis"??
Any input would be extremely helpful, Thanks
Old Jun 15, 2012 | 01:19 PM
MasterNater's Avatar
The blue wire is serial output for logging to a laptop through a RS-232 plug. The black wire is the ground.
According to the AEM EMS instructions, pin 73 is Lambda #2 input for an Evo IX, which is the same as pin 75 for an Evo VIII.
Old Jun 15, 2012 | 01:29 PM
Thanks for your input and I already got it confirmed as stated too
Now, I'm wondering if anyone figured out what was causing the mis-logging, such as 9.8, in evoscan? Was it due to the improper function or xml settings or wiring??
