EvoScan Engine Diagnostic Code Support?
Old Feb 16, 2010 | 07:17 AM
Evo_Matt's Avatar
I searched and read a bunch, but I want to double check that the DTC feature of EvoScan is NOT supported for USDM Evo9?
I downloaded the ScanTech software to give that a try. Really wish my generic code reader didn't need to be almost permanently attached to the GF's VW on the other side of the country....
Thanks,
-matt
Old Feb 16, 2010 | 09:36 AM
fostytou's Avatar
EvoM Community Team
I guess you didn't search or read enough . DTC have been supported since ~v2.5 in EvoScan. Never could get ScanTech to work on my Evo.
Old Feb 16, 2010 | 10:44 AM
Evo_Matt's Avatar
I guess not... So sad on my part.
Nevermind; I went out to car to get lunch, plugged my computer in and it worked fine...
Thanks!
-m
Old Jan 10, 2011 | 02:38 PM
sivs's Avatar
i have 2.7 i can log with evoscan and use the actuators but it wont read or clear any DTC's anyone have any clues?
Old Jan 10, 2011 | 02:40 PM
ItalyIX's Avatar
Same problem here. It will not connect to ECU to pull codes.
Old Jan 10, 2011 | 02:54 PM
Fast_Freddie's Avatar
Veteran: Navy
Same, I create a trouble ticket with Hammish, but never received a response... try submitting one as well...
Old Jan 10, 2011 | 03:21 PM
92LaserRs's Avatar
Had this same issue with the latest release, but this is with a VIII ECU. Sent in a ticket, he said he was going to look into it. Every now and then i can get it to pull the dtc's and clear. But i have to keep trying and trying. Pretty annoying.
Old Jan 10, 2011 | 05:11 PM
BoostedFury's Avatar
I had evoscan 2.7 and had the same issue. I upgraded to 2.8.0005 and its working fine now.
Old Jan 10, 2011 | 08:41 PM
sivs's Avatar
cool ill try the new version 2morrow and let u guys know if it works or not.
Old Jan 11, 2011 | 07:07 AM
92LaserRs's Avatar
I have the same problem with 2.8 just to put that out there.
Old Jan 11, 2011 | 02:58 PM
Mitsu.kid.02's Avatar
im using 2.7 and im having that problem. Ill try the upgrade and report back!
Old Jan 11, 2011 | 03:20 PM
Just downloaded 2.8 and im not having any probs now! thanks guys!
Old Jan 11, 2011 | 04:32 PM
Old Jan 11, 2011 | 05:29 PM
Boosted Tuning's Avatar
I posted this in the other thread and thought Id post it here too.
I have noticed that the DTC clearing/reading on EVOscan can be temperamental.
Usually the only way I get it to work is with laptop on, cables plugged in, open evoscan and then immediately try to read or erase DTC.
That method makes it work for me 90% of the time.
Old Feb 13, 2011 | 02:59 PM
4G63 for Life's Avatar
I am also having this issue. I've tried both v2.7 and 2.8 with very little success. I've also tried the method suggested above. I'd say it works maybe 10% of the time for me. Gotta love it. Sent Hamish a support ticket also. Just waiting for a response. What OS are you guys running?
