Enabling Alt Maps
Enabling Alt Maps
Ok been doing some tuning and testing with a friend and we were testing the ICS to allow alternate maps switching on my evo 4 with the evo 7 ecu but we seems to not be able to toggle from the high octane fuel map and the alternate fuel maps. I made the change in the tephra mods options section that says to:
FLASH ICS WHEN ON ALTERNATE MAPS? 1
ENABLE ALTERNATE MAPS MASTER? ADCOF=1, AUTOICS=2 2
And if i am not mistaken that i have to hold the ICS button for 2 seconds and release and i will see the ICS light on the dashboard blinking but i am not seeing any indication that its enabled. Is there something i am doing wrong or my evo 4 can't do map switching? Any of you e4 guys ever got this to work?
Does the sprayer light come on when you turn the sprayer on auto? Maybe the button isn't hooked up. Im not sure on the 2 seconds, I usually just hold it for a few seconds until it switches.
Not to reserect this thread, but I am also wondering just how to enable the ALT Maps via TPS or via any meens at all. Can someone pointme to a thread that has this info, on how to use the ALT Maps? Would really appreciate it, oh, and I did search far and wide for such a thread already. I am sure there is one on here though. Thanks again.
turn key to on position....... hold throttle to floor and check engine light blinks fast (lets you know its in alt map)
do it again, if it blinks slow = primary map.. its that simple
every time you flash the car it will revert back to primary map usually.. keep that in mind.
Thank you Tscompusa, what if I have my valet mode also utilizing the TPS trigger? I know for valet mode the car has to be off meening in accessorie mode, but engine not running.
Does one of the ALT map triggers allow for running motor?
If I hold the TPS while running I will hit rev limiter...
Does the TPS have to read 100% when activating alt. maps via Tephra mods? The BBK throttle body I am using only reads 93% at WOT.
Not trying to high jack a thread just didn't want to start another TPS/alt maps thread.
and also is it possible to wire some switch or button to the ecu for non E7-9 models ?
how can it be done ?
