Starting problems after injector scaling
that cranking ipw vs. coolant temps is the table you adjust......its actually a first pulse table, its what most adjust to get the starting right.
There are a few additional start-up tables as well - you need to see the advanced fuel thread by mrfred.
IMO - u probably can fix it by adjust that 1st pulse table u already have.
new IPW start values = stock scaling/new scaling * stock IPW value (from that table)
(513 old/696 new) = .737. I took that and modified the IPW table accordingly. After those changes the car seemed to start even worse.
It sounds like you are doing everything right. Just do the quick tests I mentioned and go from there.
If lowering that table truly does make it worse, then your base latency may be a bit too low and/or your base injector scaling may be a bit too high. Tuning injectors perfectly is definitely one of the harder things to do. It will take some time to get them perfect.
But, that table that you are using is the table to use for cranking IPW adjustments. There are a couple of others for the first few seconds or so after cranking as well. The advanced fuel thread explains it very well.
I have a couple of quick questions for you...
1. With the injector scaling that you settled on, does your WOT AFR match your WOT AFR when on stock injectors or did you have to adjust your fuel map to bring them back in line?
2. How do your STFT and LTFTs look during idle and cruise?
I never really tuned my car with stock injectors, someone else did. I did bunch of work on it over the winter and just started retuning it. So I do not have logs from my old setup.
2. I will verify my STFT and LTFT when I get home, but from what I remember both were within +/- 5%.
Since there is a lot more fuel tables to mess with now.....could you write a "how to" on them?
I ask because we have so many tables now and tuning has become very complicated. To simplify it would certainly make searching for hours for information less of a hassle. Guess this is what I get for not leaving well enough alone.
So it looks like it happens at cold and warm starts. l2r99gst, I did what you said and held the throttle half way in and the car started up after two cranks. Too lean I guess? I tried it when the coolant temp was as 30 and then again when it was in 60s. My current original values on the Crank IPW are:
-32 = 226.296
-18 = 108.128
-8 = 46.096
7 = 17.296
20 = 15.4
34 = 12.4
50 = 6.72
77 = 3
82 = 3
Should I INCREASE them between 20 and 77? By how much?
Thanks
-32 = 226.296
-18 = 108.128
-8 = 46.096
7 = 17.296
20 = 15.4
34 = 12.4
50 = 6.72
77 = 3
82 = 3
Thanks
So, was the starting better or worse with the throttle slightly open? If better, then you are too rich at those coolant temps. If worse, you are too lean.
If you are too rich, then you lower the numbers in that table to lean it out at the correct temperatures. If too lean, then you raise the numbers in that table to richen it up. It's important to make sure you are adjusting the correct cell, as different temps will require pretty different values. Usually warm starts want very little fuel, especially on E85, but cold starts on E85 want a ton of fuel.
I'm prettu sure you said you were on pump gas (93), but still make sure that you are adjusting only the cell(s) where your issue is.
-32 = 226.296
-18 = 108.128
-8 = 46.096
7 = 17.296
20 = 15.4
34 = 12.4
50 = 6.72
77 = 3
82 = 3
Thanks
-32 = 226.296
-18 = 108.128
-8 = 46.096
7 = 17.296
20 = 15.4
34 = 12.4
50 = 6.72
77 = 3
82 = 3
Thanks
Usually when you have to use the throttle and it fires it is a rich condition......which if those values are still stock it is probably to rich.
Try something like this:
-32 = 166.8
-18 = 79.7
-8 = 33.97
7 = 17.296
20 = 12.75
34 = 9.14
50 = 4.95
77 = 2.21
82 = 2.21
those are the current values multiplied by .7371 which is the old scaling / new scaling.......
Those look like the stock values? (don't have a stock map in front of me to confirm)
-32 = 166.8
-18 = 79.7
-8 = 33.97
7 = 17.296
20 = 12.75
34 = 9.14
50 = 4.95
77 = 2.21
82 = 2.21
-32 = 166.8
-18 = 79.7
-8 = 33.97
7 = 17.296
20 = 12.75
34 = 9.14
50 = 4.95
77 = 2.21
82 = 2.21
I guess I will go back to:
-32 = 166.8
-18 = 79.7
-8 = 33.97
7 = 17.296
20 = 12.75
34 = 9.14
50 = 4.95
77 = 2.21
82 = 2.21
And see if the car is still rick or too lean now.
So I tried everything I know how to. I increased the crank IPW, I lowered the crank IPW and same results. At Warm and Cold starts the car just keeps cranking till it finally starts. Is there anythign I can log? I mean at crank the EvoScan disconnects, so any help would be great.
I also rescaled the injectors to 680 from the exisitng 696, but once the car sits for a while, probably 10+ minutes the same thing happens. If I turn it off for about 3-5 minutes it fires right up.
Log your coolant temp as soon as possible when you get the starting issue. Then adjust only that cell. Don't adjust all of them.
If your hot starts are fine, don't touch those cell(s). If you warm starts have the issue and start better with the throttle halfway open, then adjust the specific cell and make the values smaller. Don't be afraid to go much smaller or as small as your hot start cells. In my experience, warm start needs very little fuel.
I'm on E85 and 1250s, but let me show you mine for a quick example.
Here is my altmap settings (remember this is E85, which is why the cold start cells are very high, but it gives you an idea about the warm start cells):
Code:
-32 400 -18 250 -8 140 7 56 20 3.8 34 1.6 50 1.2 77 1 82 1
