Clutch switch/NLTS/Speed sensor
Old Jun 28, 2010, 11:45 AM
TJung's Avatar
Clutch switch/NLTS/Speed sensor question
Hello. Today I've installed my clutch switch (because stock Colt doesn't have it) and stationary rev limit is working in the same way as in Evo (I had Evo 9).
I am just not sure if I don't have vehicle speed sensor plugged, will NLTS be work?
Is speed sensor really required for NLTS ?
Old Jun 28, 2010, 10:47 PM
TJung's Avatar
Up and one more thing:
stat rev limiter needs 100% throttle or doesn't matter ?
Old Jun 29, 2010, 11:30 AM
TJung's Avatar
So...because I didn't find the answer. I just take my time and check everything.
Answer is for NLTS or stat rev limit ecu MUST see signal from VSS. Maybe I should know this without work, but now I am really sure.
Regards from Poland guys
Old Sep 8, 2015, 09:57 PM
danfalcas's Avatar
do you need the clutch switch? I'm on Evo 7 RS2 Stationery Rev Limit wont work.
Thanks
foxbat
May 16, 2022 02:51 AM
mines5
Feb 10, 2018 11:41 PM
Dakota Evo
Mar 26, 2017 11:36 PM
HyperDisorder
Feb 14, 2017 04:59 PM
tephra
Aug 19, 2016 10:07 AM
Quick Reply: Clutch switch/NLTS/Speed sensor
