MUT table differences from one ROM to another
I'm in the process of moving my existing ROM table values over to my tephra v7 96260709 ROM for my JDM 8 FQ300.
Moving the basics over to the big maps etc I'm happy with, but the MUT tables are completely different. As I've changed a few bits in my original ROM for logging various things, would I be best off copying the whole table over to the Tephra ROM for simplicity?
Thanks,
Ant
Thanks,
Ant
1) if you are using two _totally_ different romids (ie 96530007 -> 96260709) then the MUT tables WILL be different... so dont copy anything
2) I modify a few select MUT table entries for my V7 mods to allow "easy" logging of interesting stuff - im sure its in my V7 thread which ones I modify
My original map is using 93660005 - so you recomend I don't copy the MUT tables?
Should I still make the changes or at least cross check the addresses that I'm logging in EvoScan?
Thanks,
Ant
Thanks,
Ant
