88591715 tephramod serious problem in 88840016 edm evoix
Old Jan 4, 2013 | 08:03 PM
newpassport's Avatar
The mod is below:
Id 1000cc injector
Kelford 272 cam
Fp red turbo
Sard FRL
Sard fuel pump
I am use tephramod v7 in my car,omni 4 bar map sensor,gm iat sensor.
The iat sensor use the maf iat sensor wiring.
It was two problem
1. the car very lean in cold start and shut off immediately.when the temp up,the idle and 02 fueltrim was normal.engine start was ok.
2. idle for a few minutes,the coolent temp up.i test driver for a miles,it was two wot.the afr was ok.but the third time.i can feel the car starts hopping or shaking violently,the afr lean out to 22.4,you can feel no more injection.the problem also in part throttle that is was about 4000rpm
Any ideas?
thanks
Old Jan 5, 2013 | 07:28 AM
Oracle1's Avatar
1) Add more fuel in the fuel map in the idle range.
2) Might need to add fuel in that region./ fuel enrichment maybe.
post a log.
Old Jan 5, 2013 | 04:50 PM
post a log.
may be not the problem
the ecu is cut fuel directly,i can see the afr jump to 22.4.
Old Apr 3, 2014 | 05:04 AM
Dragracer187's Avatar
Did you solve this?
richardjh
120
Oct 6, 2017 08:58 AM
Liquid0401
For Sale - Cars For Sale
14
Apr 15, 2016 12:27 PM
bluepeartype-s
Mar 9, 2016 07:08 AM
vlixcool
Jul 14, 2014 02:20 AM
satanbaby
Jul 8, 2012 10:03 PM
