Addresses for IPW Patch 56920008 Rom
Hi All,
I have been having trouble defining the addresses for the Minimum IPW Patch for rom 56920008. if anyone is able to assist me by defining those addresses, i wold be extremely grateful. Currently have 1600cc injectors and would loike to have them work properly, otherwise, I will be just taking them out and putting it back to stock
table name="Minimum IPW SHLL5 (stock)" address="53002"/
table name="Minimum IPW SHLL0" address="53002"/
table name="Minimum IPW SHLL0 modifier #1 (0x5345 -> 0x5340)" category="Fuel" address="3022a" type="1D" scaling="Hex16"/
table name="Minimum IPW SHLL0 modifier #2 (0x5945 -> 0x5940)" category="Fuel" address="3001e" type="1D" scaling="Hex16"/
table name="Minimum IPW Code Path modifier #1 (0x7f09 -> 0x7f06)" category="Fuel" address="3020c" type="1D" scaling="Hex16"/
The text in red i need corrected.
Thank you very much
Thank you very much
Worked out the addresses of the patch by comparing hex files. Easier to do that i first thought. Anyway, for anyone out there that wants to use the patch and has the rom 56920008, here are the addresses, tested and works as it should.
table name="Minimum IPW SHLL5 (stock)" category="Fuel" address="53002" type="1D" scaling="IPW16:SHLL5"/
table name="Minimum IPW SHLL0" category="Fuel" address="53002" type="1D" level="2" scaling="IPW16:SHLL0"/
table name="Minimum IPW SHLL0 modifier #1 (0x5345 -> 0x5340)" category="Fuel" address="3047a" type="1D" scaling="Hex16"/
table name="Minimum IPW SHLL0 modifier #2 (0x5945 -> 0x5940)" category="Fuel" address="3026e" type="1D" scaling="Hex16"/
table name="Minimum IPW Code Path modifier #1 (0x7f09 -> 0x7f06)" category="Fuel" address="3045c" type="1D" scaling="Hex16"/
tephra
57
Dec 23, 2023 09:14 AM
