Speed Density 96534706 - What am I doing wrong?
I was able to get the car to idle in open loop at about 13.5 by adjusting VE in those areas. I then turned on Closed loop for idle and checked the fuel trims and they were good. Now when i try to drive the car in open loop, the car runs insanely lean...like 18.1. Where and what do i need to adjust to fix this? No matter how much VE i add in those areas the adjustments dont seem to be great enough. I have s2 Cams with FIC 900 High Z injectors (860 Scaling give me -2.8 LTFT Lo) . This leads me to believe i am either doing something wrong or need to make adjustments elsewhere. How do i fix this? I assume the KPA to load table but i am not sure what i should adjust there or how. I would really like to get this working once and for all.
I setup my open loop tables so the it goes into open loop after 20% throttle or 45kpa. Once it does that it goes lean. So in the kpa to load table i made the load% side higher from 40kpa on. It’s becoming much more driveable. My guess keep raising it and then use the VE table to tweak it.
So i use the 96530706 and with 860 scaling in open loop is idles right around 14.5. I then set it up to idle in close close loop. And ltft hovers at around +\- 2. Then i i drive in open loop drives around the same.....just have to tweak some areas. I don’t really like driving it in closed loop.
So i have adjusted the scaling to 835 as someone above suggested. Here is where i am at so far
here is the evoscan log:
Should i keep down this path? I want to understand what exactly adjusting the kpa to load does vs the VE. The table seems to make more sweeping changes....but what exactly do the numbers mean?
have you tried adjusting the fuel map? To tune the injectors you need LTFT Mid and Low so you need to do some closed loop cruising. The nature of closed loop should lead you to stoich in those low load/rpm areas. So I wouldn't expect doing so to be risky at all. If you see LTFT Mid or low start going crazy in one direction then you know you need to adjust your scalings.
They can be fine at idle but totally messed up when cruising. Because its one set of calibrations that control both it has to be dialed in so that both LTFT Low and Mid are within a certain tolerance. Just to clarify also when I mention scaling im also bundling in latency compensations with that too. The scaling and latency comp settings will have an effect on the entire tune, so you want to get that dialed in first. Otherwise you end up chasing your tail going back and forth between them, having to readjust all your other maps after making an adjustment to scalings.
OK thats good to know. If you already had that dialed in then the settings should just carry over. Your right that if LTFT always stays at 0 then it shouldn't have any effect i.e. you have disabled closed loop cruising. If your in the ballpark with fuel, I would try adjusting the fuel map a little and see if it gets you to were you want to be. Just a disclaimer though, I have never tuned SD for this platform so take that into consideration.
Im honestly not sure which tables i should touch to achieve this. I was told to plug in target values into the fuel table and use the kpa to load and VE tables to adjust to those targets. Im trying to get an idea if that's how most people really do it.
I'm sure you have already read through this guy https://www.evolutionm.net/forums/ec...s-baro-61.html but might be worth another read. Im gonna skim through it again.
