Mitsubishi Evo 8 year 2003 speed limiter off
Hi all,
i have Tactrix.
I need speed limiter off from ecu Mitsubishi Evo 8 year 2003 with ecu MN132750 with procesor MH8206F.
I have only ecu, no car.
Please pinout for this ecu ?
Please solution ?
Very thanks for all !
Br.
i have Tactrix.
Please solution ?
Br.
What market is your car from? There may be different wiring for different markets.
This is for USDM. Unsure of any differences with the other markets.
OBD Data pin on the ECU is 62.
OBD Flash pin is 79.
+12v to pin 12 and 25 to power the ECU.
ECU Ground is pin 13 and 26.
If you're bench flashing you'll also need to have 12v and power to the Tactrix as it won't be powered from the OBD port. You should see a pulsating multicolor LED when it is in standby.
Please verify that the pinout you're looking at is in fact for your ECU. You don't want to be blowing up SMD components from sending power to the wrong place. Might as well bin the thing if you do.
Petr Cheero (Mar 18, 2019)
