Ignition Retard Limit
Hi Guys,
While looking for this knock stuff I came across the Ignition Retard limit in the ROM. 88590015 and 88580013 (9's???): 0x133e 96530006 and 94170015 (8's???): 0x173e 2 bytes, so uint16 scaling. Now it defaults to 203 (or 0xCB), I found that by increasing it to 220 I was able to run -15* as opposed to the previous limit of -10*. Now whoever disasm'd this ROM (Bez???) already found this, so I don't want to take any credit for it :) Also I don't know the proper scaling yet, but if anyone figures it out let me know :) Usual deal of test everything at idle - altmaps makes testing this pretty easy, just leave your standard map as-is, and then flick to altmaps with lots of timing retard at idle.. Cheers D. |
That retard limit was referred in this thread as well:
https://www.evolutionm.net/forums/sh...9&postcount=13 90550001 should have the same: 0x173e (uint16) Have it in my 96530006 def - but not played with it yet (actually do not need such a big retard :) |
Originally Posted by evo828
(Post 6242325)
or want to make a custom ALS using altmap ;)
great find :) Tephra, can you find the address for rom 88840016 or 17? |
mine is set to 255 on rom 90550001 but when logged it still only goes to -10 . regardless of what you put in the map.
Originally Posted by EE
(Post 6243860)
try setting 0x2038 the same as 0x133e
0x2038 should default to 0xCB as well.. edit - 2038 not 2308 :) |
Howdy dave
according to bez to get the timing to retard to anything below -10 you had to patch a few different places in the rom as there was a lot of code to stop the timing from dropping, in the rom bez sent me he has full antilag, realtime tuning and speed density setup. it would be excellent if you could incorporate these mods with your own to make a super patch, if the above could be patched along with your own mods it would mean the stock ecu would be as powerfull as any aftermarket ecu, and as bez has stated he is fully willing to share his findings for the benefit of the community ;) |
I agree it would be closer but I want more load and rpm columns ;)
Originally Posted by todd6027
(Post 6243907)
yeah because 128 would actually be limitting the retard so much that you are going into advance there... ie not allowing advance to drop below 10* or whatever...
Originally Posted by tephra
(Post 6246027)
0x2038 should default to 0xCB as well.. edit - 2038 not 2308 :) So would 0x2038 workout to be 0x2438 for 90550001 and all other e7 and 8 roms ? |
Originally Posted by cossie1
(Post 6247601)
Change it to 128 and watch the 36 counts of knock that appear from nowhere ;)
:D er, ive enough knock thanks,,think il sharpen up that chainsaw :lol: |
Originally Posted by Mellon
(Post 6247192)
Amen to that!{thumbup} |
(Post 6247722)
90550001 uses 0x173e (or 0x173f unit 8) (by the way those address's work for all E7, E8 and E9 roms)
So would 0x2038 workout to be 0x2438 for 90550001 and all other e7 and 8 roms ? I looked at the code for 90550001 and its totally different... doh Interestingly in 90550011 the 0x173e is 0xBC not 0xCB |
